Home > Tdi > new leak ...
new leak ...
since having the clutch replaced 2 weeks ago, I noticed a few spots of oil on the driveway today, looks to be coming out of the bellhousing Evil or Very Mad (not happy)
Post #143879 7th May 2012 8:22pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
If its new I would be having the the box out for a look see, could have wiggled something loose when doing the clutch. Rhubarb and custard let fly with their secret weapon.
Post #144228 9th May 2012 7:47pm
bob neville
Hi Steve
Get the indy who fitted the clutch to fix the problem, as Lambert said, something has been disturbed when fitting the new clutch.
Failing that, drop me a PM, I am sure I know somebody who will fix it for you - now where did I leave that sledge hammer ? Laughing
Good luck
2013 Defender 90 CSW - sold
Post #144238 9th May 2012 8:00pm
I spoke to the garage who did the clutch replacement and they tell me it's a coincedince that the oil leak has just started. The owner said that there was no leak when they replaced the clutch, I just find it strange that I have a leak now. I have cleaned the area and put a tray under the drain hole to see just how much is leaking out.
if it continues to leak, I'll spend a w/e taking the box out and having a look ...
Post #144239 9th May 2012 8:00pm
Bob - just sent you an email Thumbs Up
Post #144241 9th May 2012 8:04pm
bob neville
Replied Thumbs Up
Post #144249 9th May 2012 8:19pm
update on the leak, it's not gotten any worse and the engine oil has not gone down, I'm going to check the gearbox level at the w/e ...
Post #151074 19th Jun 2012 6:25am
Fortunately for an oil leak in that area, there are 3 different types of oil that can leak there, thus making a diagnosis a bit easier.
It'll either be engine oil (crank rear oil seal), would have made no difference changing the clutch. oil would be black (if it's been in for 500miles or more), and will smell "engine oily" (pull the dipstick and sniff that to get an idea)
Gearbox ATF fluid, from the mainshaft of the gearbox. again clutch change shouldn't affect that as the shaft is in a partial sleeve, so can't be pulled to one side to damage the oil seal. This oil is red coloured. so easy to identify.
Clutch slave cylinder. oil is thinner than the other two, and a golden-to-clear kind of colour. feels a bit like baby oil on your fingers, and has its own distinct smell (open the brake reservoir and sniff that). whilst changing the clutch they could have had the slave cylinder piston pop out, then someone stuffed it back in and damaged the seal. but trying to prove this would be impossible i'd have thought. and for the £30 or so for a pattern replacement (or about a fiver for a seal kit) wouldn't really be worth faffing about arguing.
Post #151096 19th Jun 2012 8:32am
Dave-H
An easy way to tell if it's slave cylinder is to add water to the leaked oil. If it goes milky and washes away then its brake fluid from the slave cylinder Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #151176 19th Jun 2012 6:41pm
cheers gents, i had a look under the motor tonight and no drips at all Shocked
good idea about adding water Thumbs Up
Post #151220 19th Jun 2012 9:11pm
