Home > Maintenance & Modifications > A decent subwoofer speaker or a 'bassy' speaker? |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
regarding subwoofer/amp combo you could look at the Focal Bus 20 or Bus 25 - this is one of the smallest of its type but packs an excellent punch - selectable bandpass filter, remote gain control. I've bolted mine to the rear floor under the seat. Needs a 12V power supply
The fitter did recommend that it could be put in the space under the drivers seat but I didn't want it muffled, or rattling the other stuff. If you do mount something like this under a seat then be prepared to have 'good vibrations' coming up your backside - not everyone's cup of tea I use an Alpine CDE 126BT head unit, 2x 3 way Pioneer rear pods mounted to the dog guard.......and Rainbow 2 way replacements for the under dash and tweeter replacements for the OEM ones |
9th May 2012 8:49pm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Any chance of some photos of your speaker positioning please? |
9th May 2012 8:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5574 |
9th May 2012 8:59pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2019 |
Loads of pics on the LaSalle Trim website now, in the customer gallery. http://www.lasalle-trim.co.uk/customergallery 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
10th May 2012 9:16am |
Decided to buy the Alpine SWE-1000, as it gets great reviews and I like the fact that all my equipment in the LR will be Alpine.
Thanks for the help chaps. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
10th May 2012 10:56am |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
Click image to enlarge this is the finished article so far. if and when i get my new 130 i will carpet rap it and put a leather cushion on the arm rest bit. |
10th May 2012 8:29pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
i have an 8" JL 8W3 sub fitted face up in my cubby box. This is powered by a JL XD400/4 amp fitted inside the cubby box. The box lid is screwed down and the sound is excellent. this set-up was recommended and installed by the car hi-fi centre specialists and i am very pleased with it.
11th May 2012 9:43am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20126 |
How wide is your cubby box to fit that? When I measured my standard one it was pretty much 6 inch wide so no good for that. |
11th May 2012 11:59am |
It looks like a bird box 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
11th May 2012 2:17pm |
hi kona, it went straight into the lid of the standard LR Cubbybox; i'm driving my 300tdi at the mo otherwise i would take a pic. i have got a pic of my old sub in the back of the box on my td5 but i much prefer it in the lid. |
11th May 2012 3:03pm |
Click image to enlarge |
11th May 2012 3:05pm |
So in your pic the sub is just under the 'cover' as such on the top of the cubby? Thank-you for the pic too
11th May 2012 3:19pm |
i believe on the 3 times i've had subs fitted to cubby boxes that they all have been attached to the inside face of the cubby box and then cover grilles fitted to the outside for protection (but i will check the puma tonight) |
11th May 2012 3:31pm |
Cheers, Much appreciated. Only problem with 8 in jobs is there is a limited range. I wonder if a 10in could be squeezed in or not shall have to check measurements. The hinges on mine would also need to be MUCH stronger |
11th May 2012 3:48pm |
