Home > Other Site Sponsors > Defender Accessory Brochure
mobilecentre
Here are a few of the upgrades / accessories that we do in a small brochure for download
http://www.mobilecentre.co.uk/images/Data_...er2012.pdf
We have a large range of products from Webasto's to plug in Td4 cruise control available.
Over the coming weeks we will endeavour to add them to the web and post pictures up on our facebook page.
We will also unveil the worlds brightest LED light bar with an output equivalent to 10,000W of halogen Twisted Evil
Post #143278 3rd May 2012 10:47pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Wow those remote battery connectors could be just the thing I am looking for - its a real pain having to dismantle the passenger seat every time I want to use my T-Max compressor.
One thing I could not workout from you brochure and website was whether the connectors come with any wiring to actually attach them to the battery?
Post #143293 4th May 2012 6:23am
mobilecentre
No wiring supplied - but we can supply whatever you need either just the parts or the cables with the ends crimped on.
IF it is just for your compressor the other option is to use a small Anderson connector
Post #143307 4th May 2012 8:01am
farmer giles
lots of very nice things there and you are only 3 miles away from me!
does fitting anderson connectors affect warranty, out of interest?
Post #143317 4th May 2012 8:59am
mobilecentre
Drilling the hole could "upset" them with regard to that panel and your body warranty.
Electrically it is the addition of a ring terminal or two so does not require modification of the OE system so no it will not affect electrical warranty if carried out properly.
Post #143318 4th May 2012 9:03am
farmer giles
cheers Thumbs Up
do you do a fitting service (not a problem if not, i use the bosch boys at alan astons)
Post #143319 4th May 2012 9:16am
Martin
Site Admin
Very smart brochure Tim Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #143322 4th May 2012 9:41am
Quite agree, very professional - Got to say, my experience of Tim's service has been First rate - 100% Thumbs Up
Post #143324 4th May 2012 9:44am
mobilecentre
farmer giles wrote:
cheers Thumbs Up
Yes we do from basic to full on conversions including re trims.
Post #143325 4th May 2012 9:48am
dnorrishill
OK that's great thanks for the answer.
Do you sell Anderson connectors then?
Post #143362 4th May 2012 1:26pm
mobilecentre
Smaller SB50 Anderson
http://www.mobilecentre.co.uk/anderson-con...9_222.html
Larger SB175 Anderson
http://www.mobilecentre.co.uk/anderson-con...9_223.html
All connectors we supply are genuine Anderson parts unlike the own brand pattern parts sold by Durite, Bolt on Bits etc.
Post #143370 4th May 2012 2:05pm
mobilecentre
We tend to carry 16mm2, 35mm2 & 40mm2 cable in stock as well as copper tube terminals for making ends to connect to the battery etc
Cable
http://www.mobilecentre.co.uk/installation...0_215.html
Coppr Tube terminals / lugs
http://www.mobilecentre.co.uk/installation...0_216.html
Post #143371 4th May 2012 2:07pm
