Home > Other Site Sponsors > Defender Accessory Brochure |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Here are a few of the upgrades / accessories that we do in a small brochure for download
http://www.mobilecentre.co.uk/images/Data_...er2012.pdf We have a large range of products from Webasto's to plug in Td4 cruise control available. Over the coming weeks we will endeavour to add them to the web and post pictures up on our facebook page. We will also unveil the worlds brightest LED light bar with an output equivalent to 10,000W of halogen |
3rd May 2012 10:47pm |
No wiring supplied - but we can supply whatever you need either just the parts or the cables with the ends crimped on.
IF it is just for your compressor the other option is to use a small Anderson connector |
4th May 2012 8:01am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
lots of very nice things there and you are only 3 miles away from me!
does fitting anderson connectors affect warranty, out of interest? |
4th May 2012 8:59am |
Drilling the hole could "upset" them with regard to that panel and your body warranty.
Electrically it is the addition of a ring terminal or two so does not require modification of the OE system so no it will not affect electrical warranty if carried out properly. |
4th May 2012 9:03am |
cheers
do you do a fitting service (not a problem if not, i use the bosch boys at alan astons) |
4th May 2012 9:16am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6616 |
Very smart brochure Tim 1988 90 Td5 NAS soft top
2015 D90 XS SW |
4th May 2012 9:41am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Quite agree, very professional - Got to say, my experience of Tim's service has been First rate - 100% |
4th May 2012 9:44am |
Yes we do from basic to full on conversions including re trims. |
4th May 2012 9:48am |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 616 |
OK that's great thanks for the answer. Do you sell Anderson connectors then? |
4th May 2012 1:26pm |
Smaller SB50 Anderson
http://www.mobilecentre.co.uk/anderson-con...9_222.html Larger SB175 Anderson http://www.mobilecentre.co.uk/anderson-con...9_223.html All connectors we supply are genuine Anderson parts unlike the own brand pattern parts sold by Durite, Bolt on Bits etc. |
4th May 2012 2:05pm |
We tend to carry 16mm2, 35mm2 & 40mm2 cable in stock as well as copper tube terminals for making ends to connect to the battery etc
Cable http://www.mobilecentre.co.uk/installation...0_215.html Coppr Tube terminals / lugs http://www.mobilecentre.co.uk/installation...0_216.html |
4th May 2012 2:07pm |
