Home > Td5 > Rediculous loss of power when cold - Help please
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
Hi,
I have a 2005 TD5 110 CSW that has an alive tuning stage 1 remap possibly some exhaust mods and a k&N panel filter. It possibly has the EGR removed, I have not checked and all the work had been done before I bought the vehicle.
Over the last few weeks there has been a massive loss in power when cold, i.e. within the first 3 miles of start up on a morning not when temps are sub zero. I drive down a lane for a few hundred yards then exit onto a main road every morning and once on this main road the landie runs as if the turbo has been disconnected, there is only just enough power to get to 30ish MPH in the first 1/2 mile. The first journey each morning is only a couple of miles for the school run and once the kids are dropped off the thing runs fine with the usual kick when it comes on boost.
It is as if the ECU is banning all turbo pressure, there is a lack of diesel or something is sticking but it disappears once warm.
Does anyone have any suggestions? It was serviced a 1000 miles ago and has only covered 55k miles. I have had this vehicle for 8000 miles now and this problem has only just started to show up.
Thanks in advance
Kevin 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #142750 1st May 2012 3:40pm
If you're not sure what mods are done to it, I'd take it to someone who could point you in the right direction first of all.
Post #142751 1st May 2012 3:50pm
excossack
I find with my 1999 TD5 (no remap only D'EGR'd & straight though mid section) that when its cold the car is really easy to stall and pulling out of junctions it needs the revs bringing up rather than just going IYKWIM.
After its got warm I'm OK. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #142761 1st May 2012 4:20pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Censored MAF? Try disconnecting it and see if any difference. The ECU reverts to default values after 30s or so, but prior to that it can have almost zero power. Yours sounds like it runs bad for a bit too long for this to be the sole cause though.
For what it's worth, mine is pretty crappy when cold, but not as bad as you describe yours.
I'd check: fuel pump, turbo wastegate (although I doubt it if it starts up bad then gets better). Can you hear the turbo spooling up during the bad period or is it silent?
Post #142783 1st May 2012 5:34pm
Kev stephenson
I will try the MAF tomorrow.
Definately can't hear the turbo when it is playing up, it just revs up into the turbo's range with no change in power. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #142787 1st May 2012 5:40pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Could a contributing factor be a faulty or gunked up Manifold absolute pressure (MAP) sensor?
I had a recent issue with some general sluggishness + turbo not appearing to spool up when expected. Nowhere near to the extent that you describe though. Cleaned up the MAP sensor itself and the electrical contacts and my problem solved.
As you'd taking off the acoustic cover to check the MAP then you could see if the EGR has been blanked off too.
If you've got a K&N filter, it wouldn't hurt to take it out and give it a clean and oil it up.
Knowing the Alive lads reasonably well (I have a stage 1 / egr blanking from them), you can be confident that they'd have had that truck running just right for the previous owner before they'd have allowed her to leave their workshop. Could always give them a shout to see if they could suggest anything else?
One other thought but it's probably a daft one as your problem seems to go away, ...... could the throttle position sensor be misreading in some way ???? Somebody far more knowledgeable than me will be along to clarify I'm sure. Jon - 110 td5 [sold]. Currently Defenderless.
Post #142827 1st May 2012 7:45pm
Kev stephenson
So thats MAP and MAF to check/clean tomorrow evening.
The K&N filter was new 1000 miles ago so shouldn't need anything.
I spoke to Gary at Alive just after I bought the truck as I knew it had been to Alive but didn't know what it had had done. I was told it had been mapped but Gary didn't have full access to his systems to tell me what else had been done, it still has standard hoses on so Gary doesn't think it has had the full Alive works.
Pressing the throttle further when the truck is struggling generally makes it struggle further, my thoughts are it is a sensor somewhere that is mis reading but sorts itself out when it is a bit warmer. My understanding of petrol engines is much better than a diesel, I would have figured this by now in a petrol.
Thanks for the help so far, I might take it back to Gary at Alive eventually as I want some more toys. Just trying to sort this annoying problem and see if it will eat into my toy fund. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #142829 1st May 2012 7:57pm
bob neville
It does sound like the MAF sensor.
A google search shows a few posts about similar symptoms and they all suggest only fitting a genuine LR replacement.
Good luck.
2013 Defender 90 CSW - sold
Post #142831 1st May 2012 8:04pm
If the K&N is that new then I'd suspect the MAF. K&N's can shed the oil they're coated with, which can play havoc with MAF sensors. Darren
Post #142833 1st May 2012 8:05pm
Kev stephenson
Will a clean with brake cleaner sort the MAF if it is just an oil coating?
Would doing a few miles in a morning be enough to see the fault disappear?
Does anyone have an idea on the cost of a new MAF from the Stealer network?
Thanks again 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #142845 1st May 2012 8:32pm
MAF's can be revived with brake cleaner, but it's not guarenteed.
To be honest, the suggestion to talk to Gary at Alive is a good one. I'm pretty sure he doesn't recommend K&N filters and he also keeps good quality MAF's on the shelf. Darren
Post #142850 1st May 2012 8:38pm
landy andy
Problem will be your MAF.
MAF's and oiled air filters don't get on Big Cry
Cleaning has never worked for me, or my mates
New one is £96 from main dealer, but Gary at alive is better, friendlier, and will stick in the post all for less money than a main dealer Thumbs Up
Andy
Post #142851 1st May 2012 8:38pm
Kev stephenson
Looks like a phone call to the fishy city tomorrow then.
This could cost me a lot of money as i may go over there 'just for a look' as well.
Thanks
Post #142852 1st May 2012 8:40pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I agree, MAF'S don't like this type of filter.
I have had a slow TD5 for ages, never really bothered me as I don't go fast. My friends 200tdi 110 was the same speed.. I have a nanocom and the MAF figures looked good 50 ish idle and 550 on full throttle. So I never thought of changing it, I recently disconnected the MAF as suggested and there was an improvement. I didn't want to buy a genuine one as they are £100 I think so took a punt on non genuine. Night and day the performance, much smoother and revs freely to 4000.
Getting a remap soon so I will get the non genuine MAF checked out.
Steve
Post #142853 1st May 2012 8:41pm
bell-auto-services
If you want a quick diag fault read and maff test im available in York if it helps.
Pete
Post #142870 1st May 2012 9:09pm
