Home > Tdi > 300tdi fitting a new aux belt |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 |
10 minutes max, very easy
15mm socket on a knuckle bar to remove to tension and a 15mm spanner needed, it's pretty self explanatory just take note of the belt track |
22nd Apr 2012 5:59pm |
cheer SoA ... I'll pick up a belt tomorrow and have a go ... just never done it before
found it in the 300tdi WSM ... looks like I can do that |
22nd Apr 2012 6:06pm |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
Dead easy bpman you will have it done in no time
22nd Apr 2012 6:58pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8077 |
POP, as above 15mm socket on a breaker bar is all you need. 2mins. Cheers
22nd Apr 2012 7:07pm |
MrsBPMan is going to collect one tomorrow and I'm going to do it tomorrow night ..
how long should the OE belts last ? Mine's less than a year old ... (and don't tell me off roading has shortened it's life ... it's a land rover ) |
22nd Apr 2012 7:38pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Suggest you take the engine number as there are 2 belt lengths and I found MY didnt help. BM52
22nd Apr 2012 9:06pm |
22nd Apr 2012 9:07pm |
my old 300 defender belt lasted 3 years (no air con) my old 300 disco with ac would last about 9-12 months.
check pulley bearings, water pump etc for wear and alignment before refitting, also your tensioner may start to squeal with a new belt, use silicone spray on the belt (not wd40!) and white grease as appropriate on the tensioner pulley. |
22nd Apr 2012 9:12pm |
found a video ...
http://www.youtube.com/watch?v=aipB15NArOc |
23rd Apr 2012 6:33am |
all done, 10 minute job .. all done and tested
good call BM52, I called the dealer with the chassis number they found the right one. |
23rd Apr 2012 6:28pm |
BM52
23rd Apr 2012 6:35pm |
tod you easy as pie
23rd Apr 2012 8:26pm |
yyyyuuupp
23rd Apr 2012 9:02pm |
