- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Lorryman100 wrote:Harryb450 wrote:So then going off what Lorryman100 says, these are the correct ones for a 90, no welding required
http://www.qtservices.co.uk/parts/defender...-guar.html
That is the ones I would have went for had I had a 90.
I see the back guard doesn't need attached to the diff/axle casing? Must just use the securing bracket over the top of the Diff as per the front ones?
Brilliant, Just to check a quick phone call would do the trick I would imagine
9th Apr 2012 5:15pm |
