Home > Maintenance & Modifications > 2012 Puma - Retro-fitting lower door seals?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Does anyone know if the new 2012 Defender door seals can be retro-fitted to a 2009 Defender? Just seems that the extra sound-proofing could be useful Smile
Post #136762 4th Apr 2012 10:58am
bob neville
Yes - I have fitted them to my 2009 110 Thumbs Up
There are a few posts about it.
http://www.defender2.net/forum/topic6370.h...door+seals
2013 Defender 90 CSW - sold
Post #136768 4th Apr 2012 11:19am
ZeDefender
Just be aware they donīt fit the "old style" Entreq stainless door sills (if you already have them). However, the MY12 Entreq sills have no rubber lip and can be fitted with the new door seals (hope that makes sense Rolling Eyes )
Cheers,
Matt Tell someone you love them today because life is short.
Post #136773 4th Apr 2012 11:44am
mlightfoot
Thanks Bob - from reading the previous post I can't quite make out the part numbers for the new seals for the front doors on a 90 - any idea?
Also, did you notice a difference in noise at all?
Post #136781 4th Apr 2012 12:17pm
I fitted them too - no water ingress when pressure washing Thumbs Up
Post #136782 4th Apr 2012 12:18pm
ZeDefender
What about everywhere else? Thinking of doing mine soon... Tell someone you love them today because life is short.
Post #136789 4th Apr 2012 12:27pm
bob neville
90 fronts are the same as the 110 fronts so you need two Front LR029309 (not handed).
Certainly quieter and as BPman said, less water ingress Thumbs Up
Post #136796 4th Apr 2012 12:51pm
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi All,
How are they fixed to the door? are they pop rivited like the early ones?
regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #136853 4th Apr 2012 5:47pm
push fit Christmas tree fittings I seem to remember
Post #136868 4th Apr 2012 6:01pm
bob neville
^^ what BPman said. Drill out the rivets holding the old strip, then check the position of the new fir tree clips against the existing holes. You may have to drill one or two new holes and the existing ones need enlarging by about 1mm. Two new holes it the front and rear upright and thats it. Remember to treat the holes to stop rust, it is a steel frame, and I also treated the inside of the doors with waxoyl.
Word of warning - waxoyl WILL deform the new seals (I've got the t shirt Embarassed ) so probably better off using Dinitrol.
Post #136888 4th Apr 2012 6:28pm
^^ yep, what Bob said, allow yourself at least 40mins per door, take off the door card, drill out the rivets, carefully remove the foam, spray around with dinitrol, allow to dry and pop the new rubber on !
Post #136904 4th Apr 2012 6:56pm
