Home > Maintenance & Modifications > 2012 Puma - Retro-fitting lower door seals? |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Yes - I have fitted them to my 2009 110
There are a few posts about it. http://www.defender2.net/forum/topic6370.h...door+seals Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
4th Apr 2012 11:19am |
Just be aware they donīt fit the "old style" Entreq stainless door sills (if you already have them). However, the MY12 Entreq sills have no rubber lip and can be fitted with the new door seals (hope that makes sense )
Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Apr 2012 11:44am |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
Thanks Bob - from reading the previous post I can't quite make out the part numbers for the new seals for the front doors on a 90 - any idea?
Also, did you notice a difference in noise at all? |
4th Apr 2012 12:17pm |
I fitted them too - no water ingress when pressure washing
4th Apr 2012 12:18pm |
What about everywhere else? Thinking of doing mine soon... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Apr 2012 12:27pm |
90 fronts are the same as the 110 fronts so you need two Front LR029309 (not handed).
Certainly quieter and as BPman said, less water ingress Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
4th Apr 2012 12:51pm |
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 |
Hi All,
How are they fixed to the door? are they pop rivited like the early ones? regards Myn. Smoke me a kipper I'll be back for breakfast. |
4th Apr 2012 5:47pm |
push fit Christmas tree fittings I seem to remember
4th Apr 2012 6:01pm |
^^ what BPman said. Drill out the rivets holding the old strip, then check the position of the new fir tree clips against the existing holes. You may have to drill one or two new holes and the existing ones need enlarging by about 1mm. Two new holes it the front and rear upright and thats it. Remember to treat the holes to stop rust, it is a steel frame, and I also treated the inside of the doors with waxoyl.
Word of warning - waxoyl WILL deform the new seals (I've got the t shirt ) so probably better off using Dinitrol. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
4th Apr 2012 6:28pm |
^^ yep, what Bob said, allow yourself at least 40mins per door, take off the door card, drill out the rivets, carefully remove the foam, spray around with dinitrol, allow to dry and pop the new rubber on !
4th Apr 2012 6:56pm |
