Home > Td5 > injector harness - how to seal?
Page 2 of 2 <12
ZeDefender
I've been asked more than once what's wrong with my Sikaflex-hands when I go into work on a Monday morning. I think I'm the only one who gets their hands dirty - the others think it's some sort of illness Laughing Tell someone you love them today because life is short.
Post #157581 23rd Jul 2012 10:13pm
K9F
Sikaflex is a complete b45t4rd to remove from your hands if you leave it on longer than 10 minutes or so. As we do not keep spirit based cleaner onboard our vessels I had to raid the spare fuel cans for the rescue boats to find something to shift it.
Once on your hands it's there for three to four days until it's completely worn off. Best thing to do if you're going to a posh do and have black Sikaflex on your mits is to reapply some white over the top, it doesn't look so obvious, unless your palour is naturally black of course. Shocked Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157594 24th Jul 2012 4:39am
K9F wrote:
..... Sikaflex 29I in not electrically conductive and is marine grade.
really Shocked
Post #157606 24th Jul 2012 6:27am
K9F
bpman wrote:
really Shocked
Yes definately! Thumbs Up You should know! I drove up to Wiltshire and gave you a tube! Writing is a bit small I suppose! Laughing Sounds bad that! (the tube giving). Embarassed
Pond filled in yet? Bet there's loads going on at your gaff with the move finished... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157677 24th Jul 2012 12:05pm
Andrew DefenderBits
United Kingdom 2003 Defender 110 Td5 HT Alpine White
We do the loom for under the cam cover here:
http://shop.defenderbits.co.uk/defender-td...-702-p.asp
at £26.95 + vat and then a clean of the red plug with some brake cleaner or anything with ipa or similar degreaser to flush the oil out, a periodic check of the plug until no more oil apprears and job done. Customers have told us that a couple of checks a month or two apart and no more oil appears.
Post #159779 3rd Aug 2012 7:42pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
So is that loom totally sealed effectively from new then Andrew? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #159892 4th Aug 2012 2:02pm
Andrew, is the inside of the connector fully potted on that loom? If not, the oil seepage will be back sooner or later.
The only way that oil can leak from the TD5 cambox and end up in the ECU connector is if it comes down the inside the insulation of the conductors. The only way it can get into them is if it leak from inside the connector. An leakage round the outside of the connector will just make a mess on the engine, and will escape from the harness bundle long before it gets to the ECU.
I have never yet seen a replacement harness with a properly sealed and potted connector available off-the-shelf.
Post #160283 6th Aug 2012 10:27am
Andrew DefenderBits
I will take a close look at the plug and report back. I thought the issue was to do with the type of wire used on the original that allowed the oil to penetrate through (I may be wrong) I will see if we can get a real close up of the plug end once we've recommissioned the photo studio after our move!
Post #164695 27th Aug 2012 10:49am
chiefstoker
Cool thanks Andrew 2005 TD5 90 Hard Top
Post #164754 27th Aug 2012 5:56pm
Page 2 of 2 <12
