Home > Maintenance & Modifications > doublecab 2nd row seat adjustment
Page 3 of 3 <123
ronwong wrote:
They are great. My sw don't have the back metal behind the seats. Mine is in the XS trim so centre mesh and half leather, your seats looks much better in fact.
Don't mind me asking, it seems that what you are doing is remove the bush, which prevents metal to metal contact. So you are making use of that 1cm or so allowance. Does it rattle? Also there is no modification to the mechanism at all in this case.
You may find that on an SW or USW you don't have the spacer thingies fitted in the first place - I think that they're fitted on the DC only, because of the limited clearance between the seat and the back panel of the cab.
Post #299614 17th Jan 2014 2:38pm
Derek Low
Malaysia 2010 Defender 110 Puma 2.4 DCPU Bonatti Grey
Theres no modification to the mechanism at all, just removal of bushes. No rattling issues.
Post #299681 17th Jan 2014 6:48pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
noted. Which means no help for SW models....
Post #300474 20th Jan 2014 3:03am
cfong02
Malaysia 2014 Defender 110 Puma 2.2 DCPU Zermatt Silver
2014 Saving my children from 90 degree sore back
Dear Derek,
Just found your thread over Google.
Got a Double Cab Pick Up, I'm planning to do something on the 2nd Row seats, before my children totally hate me for bringing them into the Defender.
I'm glad that I found your posting, unfortunately the links are expired, do you mind to post again, or send it over to me, pretty please ?
my email: cffong @ gmail. com
I live in Puchong, if you around the corner, please let me know, let me buy you tea or coffee.
cheers,
CF
Derek Low wrote:
Hi,
I know this thread has been idle for a while. I recently converted my puma DCPU to a SW and without the rear window panel longer in place, I can now modify the middle row seats to recline further. So, I thought I share some pics in case some of you are still interested with the mod.
As it turns out, You just need to remove 4 bushings installed in the hinges to recline the seats further. But you'll need to first remove the seat covers and cushion foam to have access to the hinge assembly. Once hinge plate removed, the bushing can be easily slided off.
My middle row seats now reclines further (though not significantly more) but the difference is huge in terms of comfort!
https://dl.dropboxusercontent.com/u/953767...153019.jpg
https://dl.dropboxusercontent.com/u/953767...153040.jpg
https://dl.dropboxusercontent.com/u/953767...153056.jpg
https://dl.dropboxusercontent.com/u/953767...153106.jpg
https://dl.dropboxusercontent.com/u/953767...162426.jpg
https://dl.dropboxusercontent.com/u/953767...162636.jpg
Cheers!
Post #351023 11th Aug 2014 3:59pm
H3nry
Any solution/modification for a SW?
Post #351033 11th Aug 2014 5:17pm
cfong02
Solution to recline DCPU 2nd row?
I have removed all head cushions on the 2nd row, it is now appear to be more space for the seat to recline backward. However, I'm still wondering what did Derek mean by removing the bushing, plate etc.
Can somebody help...?
Post #354220 28th Aug 2014 5:45pm
AndrewS
Where the pivot point is, where the seat backs fold forward. If you remove the trim from this area and move the seat back up and down you will see that the back rest 'rests' against bush type things in the hinge. If you remove the bush type things the seat back will recline further. I would suggest that you remove the seats from the vehicle.
Post #354332 29th Aug 2014 8:02am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I don't know how tall your kids are but removing the headrest isn't a long term solution.
You might want to have a look at the Exmoor rear seats if you want more space.
I'm now in the process letting a shop design a larger seat base to mount two original front seats on it with the right angle. If everything goes to plan I'll end up with more storage space, more legroom and a far more comfortable place to stay for my passengers in the back.
Post #354342 29th Aug 2014 8:38am
cfong02
Thanks Adnrews! By 'Trim' did you mean the black cover behind the seats?
Post #354345 29th Aug 2014 8:51am
1750gtv
United Kingdom 2003 Defender 110 2.5 TD SW Rutland Red
Can I get a prize for resurrecting the oldest thread?
I have to admit I found this by Google.
Does anyone have a pic of the bushing referred to here?
I have a double cab seat with all the trim off. I think I can see the Bush to be removed but no idea how to do it.
Many thanks
Post #1005312 24th Aug 2023 4:07pm
Page 3 of 3 <123
