Home > Maintenance & Modifications > doublecab 2nd row seat adjustment
Page 2 of 3 <123>
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Same problem here, any chance of some photos of the modification Andrew? sounds like a good solution to a stupid problem..
Alex 110 Tdci Double Cab
Post #143973 8th May 2012 5:50pm
AndrewS
Unfortunately the mod I carried out is only useful if you remove the rear of the DC cab to allow the seat backs to recline. When we converted J-Lo from a DC to an 'estate' we were able to do this.
This is the only pic I can find showing the position of the seats, basically the same as a SW.
 130's have feeling's as well you know Smile
Post #143999 8th May 2012 8:28pm
ay4alex
Okay, I guess there was a reason why they went to the effort of changing the position for the double cabs. Crying or Very sad
J-Lo is looking great though mate Laughing Thumbs Up
Post #144001 8th May 2012 8:30pm
Alex
The bulkhead is the reason.
Post #144038 8th May 2012 11:02pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
AndrewS wrote:
blackwolf wrote:
I have absolutely no idea why LR fits those brackets.
Stops them rattling
yep! I have unbloted mine and they rattle a little...
Do you have any pics on how you modified the hinges on the seats ? I'd like to do that...On long journeys the DC back seats are very uncofortable for those with long legs... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #144091 9th May 2012 11:55am
AndrewS
[quote="lrmaniac"][quote="AndrewS"]
No point unles you remove the rear of the cab. 130's have feeling's as well you know Smile
Post #144346 10th May 2012 1:36pm
lrmaniac
... Sad there are still some 10/15cm to the back of the cab that the seats could recline...thought that might do some diference... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #144348 10th May 2012 2:11pm
Derek Low
Malaysia 2010 Defender 110 Puma 2.4 DCPU Bonatti Grey
Hi,
I know this thread has been idle for a while. I recently converted my puma DCPU to a SW and without the rear window panel longer in place, I can now modify the middle row seats to recline further. So, I thought I share some pics in case some of you are still interested with the mod.
As it turns out, You just need to remove 4 bushings installed in the hinges to recline the seats further. But you'll need to first remove the seat covers and cushion foam to have access to the hinge assembly. Once hinge plate removed, the bushing can be easily slided off.
My middle row seats now reclines further (though not significantly more) but the difference is huge in terms of comfort!
https://dl.dropboxusercontent.com/u/953767...153019.jpg
https://dl.dropboxusercontent.com/u/953767...153040.jpg
https://dl.dropboxusercontent.com/u/953767...153056.jpg
https://dl.dropboxusercontent.com/u/953767...153106.jpg
https://dl.dropboxusercontent.com/u/953767...162426.jpg
https://dl.dropboxusercontent.com/u/953767...162636.jpg
Cheers!
Post #269499 26th Sep 2013 4:26am
AndrewS
This is good news for me for when I do the mods to my new 130, thanks for posting pics. They have clearly changed the seat design. The "bushings" on the earlier seats were welded.
Post #269512 26th Sep 2013 7:45am
Derek - that's really interesting stuff, thanks for sharing.
From the photos the two bushes look slightly different - one appears to have a metal insert, is that correct?
Post #269709 27th Sep 2013 8:48am
Derek Low
Yup, that's right. Its a rubber insert on one side and metal on the other from each seat.
Post #269867 28th Sep 2013 1:09am
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Derek, are you able to repost the pictures? I can't get them. Mine's a 110SW and looking to do the same.
Post #299475 16th Jan 2014 11:37pm
Derek Low
Post #299502 17th Jan 2014 5:03am
ronwong
They are great. My sw don't have the back metal behind the seats. Mine is in the XS trim so centre mesh and half leather, your seats looks much better in fact.
Don't mind me asking, it seems that what you are doing is remove the bush, which prevents metal to metal contact. So you are making use of that 1cm or so allowance. Does it rattle? Also there is no modification to the mechanism at all in this case.
Post #299506 17th Jan 2014 7:13am
Ragerover
Never looked at this yet but I'll do it once I get 110
We've done a few of the transits at work with the fixed twin front seats
Just added a 10mm spacer and longer bolts to the front mounting
Surely must be easiest option ?
Post #299545 17th Jan 2014 10:52am
Page 2 of 3 <123>
