Home > Puma (Tdci) > Long trip advice needed
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Next summer I will hopefully made a trip to Morocco with my 2.4 Td4.
I'm now looking about what to plan and what to do to avoid common problem that could be happen.
My Puma my09 now had 27.000 Km. Vacuum pump was replaced at 13.000 Km. Cluch was recently replaced under warranty and now gear change was really smooth and quiter than before.
I read and applied most of the tips suggested in this forum to avoid common problem and occasional failure.
To avoid problem with fuel (expected to be lower quality than in Europe) I will fill the main and aux tanks using a Racor funnel that separate debris up to 20 micron and water from fuel. To improve the quality of the fuel I will use a addittive that add some point of cetane, lubricity and fight water related problem.
A ScanGauge2 was already fitted to read and reset fault codes.
Before leaving I will do a complete engine oil replacement using Mobil 1 5W-30 ESP
Some question to ask:
- Do you think that vacum pump once replaced with new model could fail again ?
- What do you think about my fuel enahancement "strategy" ?
- Is the Mobil 1 engine oil Ok for the Puma 2.4 engine ?
Any other advice really welcomed!
Any opinion welcomed!
Post #132487 19th Mar 2012 9:42am
leeds
What sort of time period and distance do you anticipate?
Travelling as a solo vehicle or in convoy with similiar vehicles.
Are you on GOOD terms withyour local indy or main dealer?
Brendan
Post #132521 19th Mar 2012 12:37pm
MK
Mobil 1 is not recommended by LR but some people use such thicker oil. If using high S diesel you need to change the oil as for severe driving conditions.
Take some filters with you and a spare for the diesel filter assembly in case the shock brakes.
How did you install the Racor filter?
Thumbs Up Puma 110" SW
Post #132563 19th Mar 2012 2:55pm
MD5
Planned distance are about 6500 Km (1500km in Europe + 4000km in Morocco). Planned time is about 3 weeks.
I'm in convoy with 6 other vehicles but mine is the only Td4. Except a Defender 300 series the remaining are Toyota and Mitsubishi.
I'm in good terms with my local official assistance, my 3y warranty will expire next Jun.
About the Mobil 1 oil, if you believe something other is better, please tell me. I'm currently using the Castrol Magnatec 5W-30 A1 with oil change every 10.000km
The racor funnel filter I will use did not require installation, it's like this:
http://www.maesco.com/products/racor/r_funnel/r_funnel.html
I prefer to avoid to install a true fuel sedimentator/water separator because I read the Td4 fuel pump embedded into engine could fail a proper fuel suction by adding a second inline filter.
If you believe that vacum pump could fail again I will try to ask the dealer to supply one and return it with money refund at the end of the journey... Whistle
Anybody here with a double vacum pump failure and replacement ?
Post #132583 19th Mar 2012 4:41pm
MK
If you want a thicker oil in the 5w-30 range, Motul X-MAX. Puma 110" SW
Post #132585 19th Mar 2012 4:52pm
landy andy
Take at least two air filters, blowing them out with an air line does not work.
I would also recommend changing you box oils before you leave, personally to fully syth.
I tend to pop into Gibraltar ( nice and cheap) before the crossing and fill all my jerry cans with super, and stick them in once in the sand, where you need all the power you can get
Andy
Post #132636 19th Mar 2012 8:01pm
BigMike
A good service before you go
Decent tyres with stiff sidewalks like discoverer stt
Air compressor
No need for extended tanks
No Need to filter fuel either
Spair air filters as someone said. Check your filter daily after desert driving
2 spare fuel filters
Decent springs and shocks
That's it. Don't overload your vehicle, don't use your aircon (pump can blow and also you'll get colds)
No need to over-prepare in terms of cost
Post #132710 19th Mar 2012 10:28pm
MD5
Thanks all for the advice!
Most of the suggestion are already in use and fitted on my Puma.
I already bought a couple of spare air and fuel filter
Gear and Trasfer oil are filled with Motul fully synth oil
About Gibraltar, unfortunatly the ship from Italy will land at Tanger Med port. I will probably visit it on the return trip.
I'm now using the BFG All Terrain T/A tire, I believe they are enough for Morocco, I will take with me 2 spare wheel + tire.
About the springs, front OME medium duty + stock rear springs with Air-Lift 1000. Shocks are the Britpart cellular dynamic "orange".
As you suggest I promise to leave the aircon off for the entire travel, too much health problem in the past!
Post #132734 20th Mar 2012 6:41am
make sure you grease all the props and check them for any movement.
take spare bulbs, fuses including megafuse (just in case)
have a gread trip Thumbs Up
Post #132741 20th Mar 2012 7:18am
MD5
Which is the P/N of the mega-fuse ?
Post #133038 21st Mar 2012 8:59am
leeds
Good recovery points, plus a good bit of string.
Do not forget a decent shovel. Good for doing a dump in the desert also if get bogged down use the shovel so you reduce force needed to extract vehicle
Going for a dump in the desert? Take shovel, do business then BURN toilet paper before burying everything!
Clean hands with antiseptic gel
Brendan
Post #133042 21st Mar 2012 9:09am
BigMike
A sharp ended shovel not a coal shovel Laughing Wink
Post #133255 21st Mar 2012 9:35pm
Ashley110
South Africa 2012 Defender 110 Puma 2.2 SW Alpine White
BigMike why do you prefer a sharp ended shovel?
Excuse my ignorance Embarassed
Post #133329 22nd Mar 2012 9:04am
JWL
To chop it up into bits to make it easier to bury? Whistle
Make sure it's passed on and won't come back and haunt you? Whistle
Post #133335 22nd Mar 2012 9:29am
