Home > Puma (Tdci) > 07 Defender off-road
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
I've noticed it before, but it got realy bad while off-roading at the weekend.
While driving slowly (as you should of course) over some rocky and bumpy terrain with gentle on/off throttle control, there was a lot of banging and crashing going on in the transmission. Anyone got any clues as to what may be amiss, or is that sort of thing quite normal? It certainly didn't sound as if it were doing long term durability a whole lot of good. Had a look underneath and the prop shaft bolts were all secure.
Bosun.
Post #9832 17th Apr 2009 6:22am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
It may be that it is just inherrent. Bear in mind Defenders drive train and chassis is more like a truck than a cars. There are lots of joints, transfer box, large gearbox, larger clutch than a car and everything is big and beefy. Add to that the fact that compared to a modern saloon car the sound proofing is pants then you do get a lot of clanking and clonking going on.
I am not trying to play down your concerns but it depends what your benchmark is. I have had several Defenders and so I bought this one knowing a lot more of this noise is normal than if it were my first.
Post #9834 17th Apr 2009 7:16am
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
In extreme off road situations the prop rubs on the sump. Most likely that, LR did do a new sump, but you have to moan like Censored to get it. Thumbs Up 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #9867 17th Apr 2009 7:11pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
used defender 2008 110 off road fairly hard, seems no more "noises" than td5 if that helps
Post #9868 17th Apr 2009 7:17pm
alantd
Could be a couple of things:
1) could be the diff casing hitting the sump - you can tell because there would be witness marks on the sump. If yours is a later (late 07 build?) they may have already replaced it with the new design - again, you can tell because there would be a notch out of the front corner.
2) could be the transmission brake rubbing. This happens when the transmission warms up on some vehicles. The drum brake is not round (it should be) and so it rubs and binds as the engine slows. However - this isn't an off-road problem so you'd be able to detect it on longer journeys as you cruise up to traffic lights - there would be a juddering (very loud and noticeable if it is there at all) in the transmission. You can exacerbate it by bringing the LR to a halt on the handbrake from very low speeds. Solution is to replace the transmission brake. LR will try and 'adjust' it by slackening it off but that doesn't work. One that started out as a 2.4 TDCi 110 XS
Post #9872 17th Apr 2009 7:39pm
mse
You shouldnt...i just asked the dealer and they did it.
I do recall them changing it to change if asked about October 08 Mike
Post #9874 17th Apr 2009 7:42pm
alantd
That's good to know One that started out as a 2.4 TDCi 110 XS
Post #9876 17th Apr 2009 7:56pm
CapeLandy
South Africa
Was the TC light on ?
sometimes the sound of the breaks banging on and off are similar in sound - just a thought Puma 110 - gone
Series III 1973 - going strong
Post #9878 17th Apr 2009 9:11pm
chalky
I didn't have to moan like Censored to get mine changed !
Intact it was the exact opposite ! I asked them not to do it and they told me they had got to do it and failure to fit a new one after I had requested the diffy one to stay would invalidate any claims that I may have regarding the sump in the future ?
Check with your dealer and I'm not being arrogant here but if my dealer would have moaned to me about a warranty claim I would have dragged him over the counter ! DEFENDER XS CSW 08 TONGA GREEN
Post #9884 18th Apr 2009 7:15am
AndrewS
Our three were changed when the vehicles went in for warranty work. I presumed that there must have been a re-call type thing.
Post #9971 20th Apr 2009 8:15pm
110SEB
Yes, there was some kind of a recall - ours went in for it in the last 2 months. New sump and a pipe (i'm racking my brain and can't remember what it was). Perhaps a brake pipe thinking about it now.
Thumbs Up
Post #9972 20th Apr 2009 8:22pm
AndrewS
Brake pipes, we found out the hard way when we lost the fluid.
http://www.defender2.net/forum/topic159.html
Post #9974 20th Apr 2009 8:28pm
