![]() | Home > Maintenance & Modifications > Puma Soundproofing options |
adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204 ![]() ![]() ![]() |
Just found this interesting page that may be of help to someone.
Its an extensive list of known sound-proofing products http://www.modsandrods.tv/2012/02/07/autom...-products/ hope its useful... |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Aha thanks adiep. I'd just realised I posted on this thread a long time ago. It seems - from reading your link - that nice cheap B&Q butyl flashing is pretty much the same as the well - expensive dynamat
![]() I think I ought to go on Dragons Den with my new ( B&Q purchased ) all new expensive, massive mark up/profit margin 'Rossymat' ![]() |
is this it? http://www.diy.com/nav/build/building-mate...d=11008320 |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2227 ![]() ![]() |
My 12 2.2 110 xs came with the worst quality carpet iv seen on a landrover , cut by a drunk youth trainee with a blunt knife i think and many places none at all . Many new owners are saying that NO carpet at all . I at last have just finished all the vehicle with 1/2 inch luxury black axminster throughout , seats out , door panels off , inside battery and ecu boxes , under bonnet , foot wells , bulkhead and tunnel and all internal trim off . A big job but amazing heat preservation and sound deafaning . Iv had to alter the door catches as the carpets so thick i cant close the front doors . I have never been a fan of the pre - cut company sound proofing peices that are available at a heafty cost . Get yourself a big roll of cheep carpet and stick it to every piece of metal you can find and you will be well chuffed |
how does this carpet cope with moisture/water/dirt? is it non-absorbent?
Having watched all the replys on the FLOODS thread , i have wondered that question myself ? Although i like to polish , clean and hoover my defender i wouldnt have a problem getting it wet , how often is it over the bonnet though ? |
this is an interesting explanation of sound proofing concepts as it pertains to buildings... same physics appy i presume
![]() http://www.quietrock.com/educational-resou...paper.html they have a quietcar paint that can be sprayed in engine bay, underside/wheel arches and also inside, they claiming upto 25db noise reduction with it http://www.quietrock.com/documentation/func-startdown/352/ |
the problem i have here is the amount of sand and dust, especially with beach being so much a normal part of life, hence not being able to wash out the inside would lose some of the pleasure offered by a defender. |
Your only going to be washing out the floor panels so get the doors , bonnet , side panels , seat box , roof and back seat benches done and you will find amazing results .
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
Adiep,
Sorry im on my phone so can't give you a link, but the EvoStick that you linked to I believe is a bitchumin based flashing tape. You want a butyl based version, as the bitchumen smells when it gets hot (same smell as hot asphalt...). A friend has some in his HiLux, and it does make a huge difference, and hasn't peeled off while jet washing the floor panels (it's a farm vehicle so sees its fair share of dust/dirt/grime) ![]() |
oh i may of found something more effective than dynamat
SoundBlocker2™ Weight: 2 pounds per square foot STC rating 32 Two pounds per square foot - 1/4" thick Roll sizes: Non-adhesive backed 54" x 10' (45 sq ft.) $160 roll 54" x 20' (90 sq ft.) $318 roll 54" x 30' (135 sq ft.) $474 roll 54" x 60' (270 sq ft.) $945 roll http://www.gretchken.com/sound_blocking_vi...ndblocker2 certainly a higher STC rating and also double the mass. Anyone know how much dynamat is? |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
It's £139.00 per 36 sq metre for the extreme bulk pack to The public. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
I got a mail back from those guys, the material with an STC of 32 is apparently difficult to shape around corners due to its thickness (1/4 inch) but i guess its very good for flat floor areas. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
This company might be worth a try. http://www.carinsulation.co.uk/ Quite cheep bitumen sheet and can be paired with acoustic felts for a fraction of NoiseKiller and Dynamat.
