Home > Technical > Rain is getting in.
Page 2 of 2 <12
hopeydaze
United Kingdom 2006 Defender 90 Td5 SW Cairns Blue
+1
When I complained to a dealer service dept about a TD5 leaking they said don't worry about it too much it's a Land Rover. I replied I also have a Land Rover built in 1964 and that doesn't leak at all. That shut him up and they did replace the door rubbers etc. which worked in my case.
Good luck with the hunt
Post #128854 5th Mar 2012 2:12pm
Grockle
try adjusting the door striker on both doors so they pull tighter on the seals Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #128911 5th Mar 2012 6:38pm
Gareth
Where is the best place to get the correct Leak Check 40040 sealant from?
I know dum-dum putty is no longer available, but has anyone got an alternative? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #128916 5th Mar 2012 6:49pm
ZeDefender
If you mean the black stuff for sealing up holes etc. (old caravans were practically built with it) which gets soft when you play with it and hardens when you stop ( Embarassed ) it's called "butyl sealant" and you can buy it in strips, e.g.
http://www.ebay.de/itm/BOLT-ON-PANEL-SEALE...33578589f8
it never hardens so you can always use it again... also makes a great children's toy Thumbs Up
I think window sealant like Arbomast is similar but not so "thick"... Tell someone you love them today because life is short.
Post #128922 5th Mar 2012 7:10pm
gilmore
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
It's almost certainly the sunroof not sealing properly. The water's getting in when the car's parked up and collecting in the headlining.
cheers
rob All opinions expressed in this posting are my own and are not necessarily those of someone who knows what they are talking about.
Post #128940 5th Mar 2012 7:51pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
cheers
rob
If you think it is the sunroof remove the glass and smear silicone grease around the rubber (available from plumbers merchants). Don't be tempted to use petroleum jelly Shocked
Post #128945 5th Mar 2012 8:09pm
RRUK
When I had my Series 3 water would collect in the inside of the guttering, and then when I drove/braked would find a hole to gush out of, mostly down my neck. It was funny at first, but soon Censored me off.
It turned out the fix for my old beast was to drill out all the spot welds of the roof where it met the guttering and reseal with mastik, then rivet it down again. it never leaked again (from the roof)
Very Happy
I doubt you will want to do this BTW. But I could also buy it off you if you want Whistle 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #128958 5th Mar 2012 8:28pm
ZeDefender
If it's running down the roof under the rear edge of the metal frame, you might try the "creeping crack sealant" that some on the forum swear by... Tell someone you love them today because life is short.
Post #128960 5th Mar 2012 8:30pm
Page 2 of 2 <12
