Home > Maintenance & Modifications > 2.4 Puma Replacement Pipe
nick272
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi, I have a 2007 2.4 Puma Defender and was looking about fitting a mid silencer replacement pipe and/or a 'de cat' pipe. Its purely for improving the sound. I know the TD5s sound good with these but does anybody know if the puma does? would be a great help if u could link me to a video or a sound clip etc. I have looked about and cant find any so far though. Sad
Post #127432 28th Feb 2012 2:36pm
The Boy
I am having mine done in a month or so (warranty running out then). Stainless steel with a dummy cat. Had it measured up already and having two exits (one at each corner). Been done by a company in Suffolk, owners are land rover nuts. A mate of mine has also ordered one that is been fitted to his 300tdi with vtn turbo and is been fitted this week I think.
Post #127433 28th Feb 2012 2:47pm
nick272
do u reckon yours will sound good then? i probably wouldnt fit a whole new kit. Only the mid silencer probably. Wouldnt mind seeing/hearing what yours is like after its fitted though!
Post #127441 28th Feb 2012 3:08pm
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
No difference on mine before and after. De-cat + mid-silencer replacement. Sorry Rolling with laughter Puma 110
Post #127445 28th Feb 2012 3:13pm
The Boy
Well after they put it up on the lift I was horrified to see how much corrosion was on the exhaust! The centre box was very rusty and the steel 10mm hooks that are welded to the system along its route were a minimum 50% rusted through. So I am having the whole lot changed to stainless steel in April. I am having a centre box on it but that is smaller and sits higher up than the original but no tail box. They more or less do anything you want so you could if you wanted have just the straight through centre and a tail box. http://demandengineering.co.uk/
Post #127446 28th Feb 2012 3:18pm
nick272
probably explains the lack of videos/sound clips...
Post #127447 28th Feb 2012 3:19pm
The Boy wrote:
... Stainless steel with a dummy cat. ...
What's the reason for the dummy cat?
Post #127449 28th Feb 2012 3:21pm
Denis
I think so. As far as I know for better sound you need to change/remove rear (small) silencer
Cheers Puma 110
Post #127450 28th Feb 2012 3:21pm
nick272
Thanks the Boy, will check them out. Denis, do u know if u have to get rid of all of the silencers to get a good sound, or is it just the rear one?
Post #127452 28th Feb 2012 3:30pm
The Boy
With all this stuff about cats might need to be left on in order to pass the mot I was a bit worried. I know some have said it will only apply to petrol engines but if it doesn't I will be up the creek. If it is defiantly only petrol then there will not be a problem and a simple pipe will suffice.
Post #127455 28th Feb 2012 3:40pm
Denis
Nick - just the rear one imo Puma 110
Post #127460 28th Feb 2012 3:52pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
&list=UUVjoa15O9LXMp_kQe3C_ahg&index=35&feature=plcp
Post #127490 28th Feb 2012 5:57pm
nick272
Thanks Denis, I have seen those videos already haha, im not sure they show enough to convince me though. Wish i could find one of them going for a bit longer.
Post #127502 28th Feb 2012 6:31pm
Dave-H
Made a difference on mine, and it sounds ok [least i think so]
Short clip here
http://www.facebook.com/photo.php?v=358156820872601 Guns and Landrovers .... anything else is irrelevant.
Post #127530 28th Feb 2012 7:47pm
nick272
Dave, i would have to add you as a friend first, u cant upload it to this easily? Thanks
Post #127531 28th Feb 2012 7:50pm
