Home > Puma (Tdci) > Towing Electrics |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Hello foiloman - there's a thread on here already about this that will give you some useful guidance, but essentially there is a plug connector behind the offside rear lights, accessed through the wheelarch behind a plastic panel held in place by one single screw & nut. The electrics with 7 pin plug on it, bought from LR or elsewhere, plugs into that socket and threads through to your tow bar or to the hole in the X-member.
Good luck. |
6th Apr 2009 1:48pm |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 |
Yes, just lie on the ground and put your arm up into the wheel arch and you will feel a plastic flap that will pull away, then at the top of the void the Grey plug is clipped in place, yank it down and plug it into your towbar electrics - that's it.
6th Apr 2009 3:59pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
The genuine 12N wiring kit from Landrover was about £22,, then went up to £60 odd, IIRC,, but is a plug and play kit, Its the way i have always done it,, Just fitted one to the D3, really simple, but a tad expensive !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
6th Apr 2009 5:19pm |
foiloman Member Since: 23 Dec 2008 Location: Berkshire Posts: 9 |
Cheers for the replies.
I'll take a look under the wing at the weekend... 2.4 110 XS |
8th Apr 2009 4:47pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Yes it seems between £50 and £60 now
anyway this is your baby: note it should have a cover on...mine hadnt and it on collection it had fallen down...took me a year to get round to cleaning it...which is now done. Mike |
8th Apr 2009 6:40pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2046 |
Got my wiring kit from a trailer and tow bar fitters near me. I can't remember what it cost me now.
Might be cheaper than Land Rover price if you have one near you. DAZ110 |
8th Apr 2009 6:50pm |
