Home > Puma (Tdci) > Towing Electrics
foiloman
Towing Electrics
Hi
I've fitted a towbar to my 07 TDCi with no electrics.
I'm now thinking of adding Electrics to it.
Does anyone know if the wiring is already there, and I just need to find the connector?
Or do I need to put in all the wires?
Cheers... 2.4 110 XS
Post #9469 6th Apr 2009 12:08pm
110SEB
Hello foiloman - there's a thread on here already about this that will give you some useful guidance, but essentially there is a plug connector behind the offside rear lights, accessed through the wheelarch behind a plastic panel held in place by one single screw & nut. The electrics with 7 pin plug on it, bought from LR or elsewhere, plugs into that socket and threads through to your tow bar or to the hole in the X-member.
Good luck.
Thumbs Up
Post #9471 6th Apr 2009 1:48pm
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
Yes, just lie on the ground and put your arm up into the wheel arch and you will feel a plastic flap that will pull away, then at the top of the void the Grey plug is clipped in place, yank it down and plug it into your towbar electrics - that's it.
Post #9478 6th Apr 2009 3:59pm
TJ101
The genuine 12N wiring kit from Landrover was about £22,, then went up to £60 odd, IIRC,, but is a plug and play kit, Its the way i have always done it,, Just fitted one to the D3, really simple, but a tad expensive !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #9481 6th Apr 2009 5:19pm
foiloman
Cheers for the replies.
I'll take a look under the wing at the weekend... 2.4 110 XS
Post #9550 8th Apr 2009 4:47pm
mse
Yes it seems between £50 and £60 now Exclamation
anyway this is your baby:
note it should have a cover on...mine hadnt and it on collection it had fallen down...took me a year to get round to cleaning it...which is now done. Mike
Post #9553 8th Apr 2009 6:40pm
DAZ110
Got my wiring kit from a trailer and tow bar fitters near me. I can't remember what it cost me now.
Might be cheaper than Land Rover price if you have one near you.
DAZ110
Post #9554 8th Apr 2009 6:50pm
