Home > Technical > Fault Code P1169
shingwell
Fault Code P1169
Hi,
Just wondering if anyone on here has a list of Puma Fault Codes? I have an occasional problem when the engine is cold and have finally managed to log a fault code of P1169 using a ScanGauge, but I don['t know what it means and the local dealer has not got back to me. Rolling Eyes
Thanks!
Post #9256 31st Mar 2009 8:56am
log11
Greece
Fuel Rail Pressure Sensor in range but high
Post #9257 31st Mar 2009 9:40am
Femund
Norway 2008 Defender 110 Puma 2.4 XS CSW Java Black
Have a look at http://www.troublecodes.net/OBD2/ 08MY Defender 2.4 SE
Post #9258 31st Mar 2009 9:49am
shingwell
Thanks for the info and for the web site; that's definitely worth remembering!
Post #9262 31st Mar 2009 12:07pm
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My truck threw a code tonight, same symptoms that the recent software upgrade is supposed to fix - engine reasonably cold, lost power in all gears, engine light came on. Ignition off, restarted and drove home with the engine light on.
LRA sent an AA bloke and all he could do was capture the code which I think was P1169 and reset the light.
Will ring the service centre tomorrow and get it booked in.
Post #21897 11th Jan 2010 8:55pm
alantd
Don't let the AA/RAC reset the code. Unless it is still in the system, LR can't do anything about it.
I had a similar issue on a VW recently. RAC reset the code and the dealer wouldn't move forward. One that started out as a 2.4 TDCi 110 XS
Post #22145 14th Jan 2010 11:31pm
