Home > Technical > Fault Code P1169 |
log11 Member Since: 31 Mar 2009 Location: ATHENS Posts: 28 |
Fuel Rail Pressure Sensor in range but high
31st Mar 2009 10:40am |
Femund Member Since: 21 Apr 2008 Location: Norway Posts: 12 |
Have a look at http://www.troublecodes.net/OBD2/ 08MY Defender 2.4 SE
31st Mar 2009 10:49am |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 |
Thanks for the info and for the web site; that's definitely worth remembering!
31st Mar 2009 1:07pm |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
My truck threw a code tonight, same symptoms that the recent software upgrade is supposed to fix - engine reasonably cold, lost power in all gears, engine light came on. Ignition off, restarted and drove home with the engine light on.
LRA sent an AA bloke and all he could do was capture the code which I think was P1169 and reset the light. Will ring the service centre tomorrow and get it booked in. |
11th Jan 2010 9:55pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Don't let the AA/RAC reset the code. Unless it is still in the system, LR can't do anything about it.
I had a similar issue on a VW recently. RAC reset the code and the dealer wouldn't move forward. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
15th Jan 2010 12:31am |
