Home > Td5 > REAR WORKING LIGHT |
glyn.c Member Since: 30 Oct 2011 Location: east devon Posts: 33 |
hi could anyone suggest a handy point to pick up a supply for a 55w rear working light on my 90 please ? or would it be best to just run a separate supply via a relay from the battery i intend to fit a switch to the light inside either way and not just rely on the switch on the light housing ALL THE BEST
GLYN |
5th Feb 2012 5:50pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Look in the o/s corner of the tub, behind the trim, there might be a black connector with a permanent live, remove your speaker panel complete, usually double sided sticky taped on.....for speed
5th Feb 2012 8:16pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Direct from the battery with a relay is how i did mine and a switch on the dash to power it 2004 TD5 Defender 90 xs station wagon
6th Feb 2012 7:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Likewise I would do the same. What type of switch did you use? |
6th Feb 2012 7:53pm |
Halfords Round Rocker Switch 10 Amp Max HEF356 2004 TD5 Defender 90 xs station wagon
6th Feb 2012 8:38pm |
