![]() | Home > Td5 > REAR WORKING LIGHT |
glyn.c Member Since: 30 Oct 2011 Location: east devon Posts: 33 ![]() ![]() |
hi could anyone suggest a handy point to pick up a supply for a 55w rear working light on my 90 please ? or would it be best to just run a separate supply via a relay from the battery i intend to fit a switch to the light inside either way and not just rely on the switch on the light housing ALL THE BEST
GLYN |
Look in the o/s corner of the tub, behind the trim, there might be a black connector with a permanent live, remove your speaker panel complete, usually double sided sticky taped on.....for speed
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
Direct from the battery with a relay is how i did mine and a switch on the dash to power it 2004 TD5 Defender 90 xs station wagon
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20599 ![]() ![]() |
Likewise I would do the same. What type of switch did you use? |
Halfords Round Rocker Switch 10 Amp Max HEF356 2004 TD5 Defender 90 xs station wagon
