Home > Puma (Tdci) > EGR Valve Stuck Open?
ian964
I've been having a bit of a problem with the car today, I think because the EGR valve may be stuck. Car was running fine (with BAS remap, pre EGR close version). I stopped for 15 minutes, then when I restarted and drove off, there was no power and loads of grey smoke from the exhaust. Power picked up a bit if the revs went over 2000, but still loads of smoke. MIL light came on as well.
I've tried putting back the original map and clearing the fault codes, but this has made no difference. MIL light is off, fault codes showing now are P0100 (Mass or volume air flow circuit) and P0404 (Exhaust gas recirculation control � circuit range/performance). The EGR cleaning cycle on switch off is NOT happening now, whereas it had been previously, which is what makes me think the EGR is stuck, does this seem a reasonable assumption?
Next step is to remove and clean the EGR valve, at least to make sure it is closed, however I'm not sure how/where it is. Can anyone please give me a few pointers on removing it?
Thanks
Ian
Post #121364 4th Feb 2012 11:35pm
K9F
Not removal, but this thread should point you in the general direction, would suggest using brake cleaner as cleaning agent. Thumbs Up
http://www.defender2.net/forum/topic2227.html?highlight=egr+blank
Page three on this thread too shows you where it is in photos...
http://www.defender2.net/forum/topic3115.h...p;start=30 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #121394 5th Feb 2012 12:39am
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Turbo hoses all sound? 2009 XS 110 Utility Stornaway Grey
BAS re Remap, BAS Turbo, BAS Spec Modified Airbox, Twisted Side exit Decat Exhaust, Allisport Cooler and Hoses, OME Sport Shocks, Kangaroo Paw Discs.
2001 Discovery II
Porsche Speedster Replica 1956ish
Post #121420 5th Feb 2012 10:00am
ian964
Thanks for these - turbo hoses look OK, EGR valve located now! I'll try giving it a tap first,then take it off and clean f that doesn't work.
cheers
Ian
Post #121462 5th Feb 2012 12:07pm
ian964
Well a few whacks with a hammer (the handle rather than the other end!) seems to have freed things up, and the car is running normally for now. The EGR probably should be replaced, but I'll see if I can get the EGR update to the BAS remap and try that now the valve closes.
Ian
Post #121485 5th Feb 2012 1:47pm
wslr
You can get an EGR cleaner which you spray into the air inlet when the engine is on a fast idle.
On the quiet, LR were doing this when the D3 was going through early EGR issues, just to keep the vehicles going for customers before they could get them into the workshop.
Here is the product:
http://www.wynnoil.co.uk/products-wynns-featured-egr3.htm
Post #121487 5th Feb 2012 1:59pm
Lorryman100
Now that it is working again, unplug it (after cleaning cycle so you know it is closed) and get the EGR closed upgrade fitted soon as. You will get the MIL on and a couple of DTC's and maybe limp mode the first time you start after removing the plug, just switch off and restart to clear the limp mode and live with the MIL until the egr remap is on. Thumbs Up
Post #121488 5th Feb 2012 2:06pm
ian964
Done just this, MIL light on but otherwise all fine. Thumbs Up
Thanks
Ian
Post #121533 5th Feb 2012 6:04pm
Bryden
South Africa 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I have had a slightly different experience, my 2008 was my first Defender and initially ran like a pig, better after freeing up the turbo actuater. It then accelerated slowly up to 2200 rpm before taking off on turbo boost. even though it had the normal click-clack from the egr on shutdown I decided to unplug the egr from the loom.
A test drive revealed a completely different vehicle that now pulls well from 1500 rpm and will accelerate up a slight slope in 6th gear from these revs. I have no engine light on but wait in anticipation.
Post #121709 6th Feb 2012 8:58am
Naks
that is very strange...
What do mean by 'freeing up the turbo actuator'? --
Post #121717 6th Feb 2012 9:57am
Bryden
The plate that activates the turbo variable angle vanes was stuck, a few taps freed it
Post #121720 6th Feb 2012 10:14am
