![]() | Home > Technical > Differential Issues |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
I have a friend who works in the R and D Dept at LR, when I picked up my Defender 90 in May he told me in strictest confidence
![]() I am also led to believe that a number of people have succesfully got their entire truck repalced due to numerous problems. When this site becomes as well used as Disco3.co.uk we can expect more info. Hopefully that will be sooner rather than later 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Fixed the table for you chap.
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
Well there are a number of us over here watching with interest to see if any of these problems are headed our way. My new Defender is ordered but I don't as yet know what the build date is/was. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Confirmed today that my 110 Utility with heavy duty suspension has light duty 2 pin diffs. When I ordered the vehicle I was not given a choice between 2 or 4 pin diffs. Clearly the 2 pin is not strong enough for a loaded 110 thats used off road as a work vehicle. I am waiting for LR to advise me as to what they intend to do to fix the problem.
I also have a new 110 XS CSW waiting to be collected. I have asked the question 'So what diffs are in the new one then ![]() ![]() ![]() |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Makes me glad we didn't go for TC and ABS when we got our 90. LR have come good on the EPB on the D3 for me (replacing everything and recalibrating using a new electronic calibration) although there's still no public acceptance of an inherent weakness, so fingers crossed they accept your request on similar "case by case, sir" terms.
It will be nice, but I suspect a little chilly for satan's liking, when LR openly admit a design weakness and make wholesale changes / recalls on the D3 EPB and the Defender diffs, but we live in hope. ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Up date
The vehicle requires a new diff and axle casing. The diff has arrived, however the casing is on back order with no sign of one turning up in the near future. There is a complete front axle available and I am waiting to see if LR will allow the new complete axle to be released and fitted to my car. |
Up Date
LR have agreed to change the front complete front axle. Thats got a 2 pin diff in it ![]() |
dshickle Member Since: 09 Oct 2007 Location: Epsom Posts: 36 ![]() ![]() |
HI Andrew,
I'm just in the process of picking up a may'07 90XS CSW. Which I intend to use for off-road fun as well as general driving, and some trailer activity If I read you post correctly your saying that the diff's are not up to the task, but is that because you are doing major off-road with load as a work horse. Or is there a risk to general driving as I intend. I'm not sure I fully understand the implications here, but it doesn't sound good. David |
You should be OK with a 90 Chap the vehicle is a lot lighter. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Thanks for taking the time to post Andrew,
mmm,, does not look good, ![]() Main Brian James Trailer Dealer for South West UK |
Got it back today. She had a new front axle fitted. They also found that the rear prop/park brake drum bolts were loose. Add to this, the fact that the turbo/exhaust manifold bolts were also loose makes me think that LR could have build quality issues.
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Fills me with confidence for collecting my 110 next week
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
not only the highest torque from the engine but also the lowest gearing of a stock LR - 1st some 33% (IIRC) lower than the td5 gearing.
ask LR if they had many diffs go on the launch of the model............. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
