Home > Maintenance & Modifications > Battery powered tyre inflator
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi, Anyone know of a good one that is quick and easy to use for 4x4 tyres. Don't want an on board one as i will use it on about 4 different vehicles.
I have a standard Ring one but it takes ages and ages....... Sad BM52
Post #119528 29th Jan 2012 3:59pm
leeds
On board air compressors with a 9 litre tank is one of the fastest ways of inflating tyres but not the cheapest option.
Cheap inflators do just not work with 4 x 4 tyres.
Have used a Truckair?? Not worth the money.
Have both a Viair 400p available from Matt Savage here but currently use and prefer the ARB one available here
With electrical ones fit an Anderson connector. Also carry a spare 30 amp maxi fuse.
Also get an inflator with built in gauge Thumbs Up
Brendan
Post #119530 29th Jan 2012 4:30pm
Laurie
Post #119533 29th Jan 2012 4:42pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Laurie wrote:
These look good....
http://www.ebay.co.uk/itm/T-Max-12v-Portab...0544780009
Thats exactly what I have and its great. It comes with long wires and an extendible hose, so its really handy for pumping up trailer tyres etc.
Post #119572 29th Jan 2012 6:46pm
bm52
Hi and thanks, i like the look of the ARB but probably best suited based in one vehicle.
I've been doing a bit of research and the TMax does look good. just need to make sure it will work from a cigarette lighter, especially as it will be used on 2 x LRs, 2 standard euro boxes and probably my son's LR as well.
cheers BM52
Post #119631 29th Jan 2012 9:12pm
leeds
The ARB is readily portable between vehicles, yes we take it between our 3 LR's
Do not, repeat NOT use that Tmax compressor from a cigarette lighter! Reason being most 12 volt sockets are rated at 16 or 20 amps. That compressor like most compressors is rated at 30 amps.
Either use crocodile clips direct onto battery or use an Anderson connector, do not use a 12 volt socket.
Brendan
Post #119637 29th Jan 2012 9:24pm
bm52
Messages received and thanks. 30amps into 20 is not good Shocked
so it looks like i need to keep the weedy one or do it properly !
cheers BM52
Post #119639 29th Jan 2012 9:29pm
rossy
I got a fairly cheap 'torq' one from B&Q (€ 17). Works really well. This is the first motor I've owned where standard foot pumps are not really practical as it just takes too long.
The B&Q cheapie raises tyre pressure in a std 235/85 tyre by 5 psi in less than a minute but I always use an accurate pressure gauge afterwards to check Thumbs Up
Post #119647 29th Jan 2012 9:50pm
landy andy
cheers
A happy medium is the Truckair.
Andy
Post #119655 29th Jan 2012 10:02pm
I've got a Truckair that I've had for years and it serves its' purpose in that it'll run indefinitely without melting its' innards, but it's still pretty slow. If I were buying one today, I'd probably go for something like the T-Max one instead, as it has a greater cylinder capacity so it works faster.
The ARB one is a good unit too, but it's around four times the cost of the T-Max. Perhaps justifiable if you're doing a lot of driving that requires the tyres to be aired down and re-inflated repeatedly, but for occasional use then the T-Max or equivalent will do the job. Darren
Post #119662 29th Jan 2012 10:13pm
WarPig
What length of hose does the Tmax have? If I connected it to the anderson connectors on my seat box, would it reach to the tyres of a hitched up caravan?
Post #119668 29th Jan 2012 10:20pm
Unlikely, I would think. I'd guess that would be 8 or 9 metres to the off-side wheel. Darren
Post #119673 29th Jan 2012 10:27pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Viair 400p top kit
Post #119880 30th Jan 2012 8:21pm
Gareth
I have the Viair 400p, its been mostly very good. Two problems I have encountered, first the bag has fallen to bit long ago. Second, the flex cracked where it exits the unit next to the switch, it shorted out and blew the fuse. Its caused by the repeated wrapping of the cable around the unit.
Mine has done numerous off road trips, including 2 x Morocco where it got a lot of use.
I had to replace the flex with something more flexible.
 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #119892 30th Jan 2012 9:00pm
Wacker
They do a really good one in Costco , plenty of power, next time I'm in I'll have a look at who makes it.
Post #120398 1st Feb 2012 7:18pm
