landydubai
ARB http://www.arb.com.au/products/arb-air-compressors/ | |
CKMTP12 it's the dogs bzzzzzz
High flow, twin motor, dual cylinder, portable 12V DC air compressor with 4L air tank, 6m (20ft) durable high temp air hose, inflation accessory kit and air blow gun
Designed for inflating tyres and other equipment
Suitable for many air tools
Class leading flow rate
100% duty cycle
Sealed for moisture and dust resistance
Hard anodised cylinder bores for reduced friction
Teflon impregnated carbon fibre piston seals for maximum trouble free life
Anodised mounting bracket dissipates motor heat
Integrated pressure switch, relays and IP55 (waterproof/dustproof) brushless fan cools electronics, motors and cylinder heads
Quality components for quiet operation and extra long life
Constructed of lightweight, high strength engineering grade materials
Over-pressure safety valve equipped
Motors are internally thermal protected against extreme temperature damage
Heavy duty in-line maxi fuse for each motor provides professional circuit protection
Conveniently mounted in a durable, high impact polymer carry case LandyDubai
Keep the shiny side up!
09 110 XS BAS remap
09 90 pick up BAS remap
08 D3 V8 G4 Spec
Bentley Speed GT 2009
G55 2003
Ford Raptor 2010 - new toy!
1st Feb 2012 7:23pm |
