![]() | Home > Td5 > Speedo not working either! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Do you get the mileage figure on the speedo? (question is really aimed at is there power getting to the speedo)
Or is it the transducer not giving as signal to the speedo head. |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 ![]() |
I've got power ok. Apparently I've got wrong transducer - should be a green one. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 155 ![]() |
Hi done this same converstion had the same problem has your transducer got 2 or 3 pins in it mine had two so had to change it for a td5 one. The plug also only had 2 pins in had to add another one for the earth. Phil |
Keith Gott refunded me for the black transducer and supplied the green one, both had a three pin plug. Speedo now works as it should. ![]() 1975 Triumph Stag 3.0 V8 |
