Home > Puma (Tdci) > engine has a flat spot @ 2000rpm
MarkVesnaG
Australia 2011 Defender 110 Puma 2.4 SW Stornoway Grey
Ive had my puma 110 for a year now it has 6,600km on the clock now, and ive noticed today when coming back from the Airport that when i was moving off in traffic I got this flat spot @ around 2000 rpm. no warning light, nothing like that just feel as if its not right. Confused
Post #116757 19th Jan 2012 2:00pm
Lorryman100
Is it remapped? Also what is the air temperature where you are?
Brian.
Post #116764 19th Jan 2012 2:28pm
dgardel
Italy
If it is no remapped, chech the EGR valve.....
1. Switch off the engine
2. disconnect the EGR valve electric connector
3. Test drive
4. Switch off the engine
5. connect the EGR connector
if at point 3 the flat spot is disapeared, it is the EGR Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #116785 19th Jan 2012 3:40pm
MarkVesnaG
Thanks guys for your input, I have also done some investigating of my own and I dont know how to put this BUT it maybe the way i drive it. Embarassed Embarassed yer I kind of drive it Whistle mmmm moly coddle it alittle, Embarassed I drove it hard today and it went realy well, so Ive leant something today about driving a Defender Very Happy
Post #117034 20th Jan 2012 1:24pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Mine has always done that ... around 1900/2000 rpm ... I read someqhere on this forum that this was normal ... isn't it ? Only dissapears once remaped ? Question Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #117047 20th Jan 2012 2:12pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Drop it into Davis Performance and let Bruce take a look. Which then will be passed onto me, to have a look! Wink
Post #117185 20th Jan 2012 10:23pm
dgardel
Italy
Again,
3. Test drive
try this and report.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117200 20th Jan 2012 11:49pm
lrmaniac
Embarassed ..wich is located somewhere near ? what ?.... any pic, schematics ? Embarassed Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #117245 21st Jan 2012 10:04am
Lorryman100
I would suggest that you confirm the EGR is working first before disconnecting the EGR plug. Check that it completes the self test cycle (5x chukka chukkas) then disconnect. That way you know that the EGR valve is closed. If it is at fault you should have other symptoms though Confused
HTH Brian.
Post #117335 21st Jan 2012 6:21pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Lorry Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117387 21st Jan 2012 8:01pm
