![]() | Home > Maintenance & Modifications > Dual Battery Setup |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Fitted the 2 batteries and it was a tight fit for the VSR
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Got your old one ready for bubbles then
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
hi
stupid question, but what is the purpose of fitting a dual battery system? Cheers keith puer claudius |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
In general it is to run additional accessories off so that you don't overload the main battery. In my case this is so I can have fridge in the vehicle which runs of the auxiliary battery and doesn't effect the charge of the main battery if the vehicle is off for the day. 110 2.4TDCi
110 300Tdi ![]() LROCV ::: AULRO.com |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
I was wondering the same i thought it was for a winch NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
That to - although i know many people (like me) who run the winch off the main battery still and have a second (not like me on the 90 anyway) as a backup. Mike Last edited by mse on 22nd Mar 2009 6:52pm. Edited 1 time in total |
Cheers guys
Sonic3D
so did ylu do the conversion yourself? or have someone do it for you? if you did it yourself, what parts are used? like the sound of a second battery, as we are about to embark on a new activity called camping! and the appointment with the shrink is the monday we get back. Cheers keith puer claudius |
The parts i used are from Devon 4x4 - battery tray - 2No PC1500 Odyssey batteries - 300amp Voltage sensing relay. Plus im also fitting a switch on the cubby box that links the 2 batteries together if needed
Sonic3d
any chance you could draw, scan and email a schematic drg for the wiring, that way i can work out what i am doing! Cheers keith puer claudius |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Sonic
what did you do with the jack, wheel brace and chock? Thinking of reloacating mine soemwhere tidy so would be interested |
If you look on the BEP Marine site there are wiring diagrams there
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
Sonic Are those batteries smaller in size compared to the OE one? Puma 110" SW ............................................................. Earth first. Other planets later |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Good choice!! I have gone for the same setup but have gone for a IBS split charge system- it does cost a bit but for what I want I belive it will pay back what it has cost me. A dual battery system is a must if you are adding extras such as winches, inverters, freezers and also a good idea if you have many extra lights. Glyn |
