Home > Maintenance & Modifications > Heat Shot washer heater
Page 1 of 3 123>
ZeDefender
Anyone got one of these?:
http://www.brookwell.co.uk/item/8152/heat-...ter-heater
I'd be interested to know what you think and how to do the wiring Wink
Matt Tell someone you love them today because life is short.
Post #113371 7th Jan 2012 10:28pm
Lorryman100
Cobs did it a wee while ago with the Alphatherm unit.
http://www.defender2.net/forum/topic4787.h...alphatherm
Post #113373 7th Jan 2012 10:33pm
pom
Wonder if the disco3 heated squirters could be retrofitted?
Pom
Post #113375 7th Jan 2012 10:40pm
dgardel's your man for those jobbies Thumbs Up
Post #113381 7th Jan 2012 11:00pm
ZeDefender
Thanks for the info Thumbs Up
That looks very interesting for me - have to find out if the Brookwell one triggers on overvoltage too Very Happy Tell someone you love them today because life is short.
Post #113383 7th Jan 2012 11:03pm
I have a few questions:
1. does it stop the washer bottle from freezing ? (No)
2. do you run the risk of cracking your windscreen?
3. does it draw the hot water back into the washer botter ? (otherwise it might freeze the nozzle & pipes)
4. £180 seems a bit steep
IMHO the perfect system would:
1. warm the washer fluid
2. push the water up to the jets, then pump it back to clear the pipes
3. cost about £40
Post #113403 8th Jan 2012 8:55am
BigRuss
Well,
Yes if the water is hot enough it will crack the windscreen, but I don't think they could get the water hot enough for that.
You do have to be careful of what water you use as heating water and then breathing in the steam is how legionella is contracted!
And no if the water bottle is frozen it probably won't work Thumbs Up Russell
2011MY 110 XS USW Black
Post #113419 8th Jan 2012 10:06am
ZeDefender
All good points to be considered.
My antifreeze-wash goes down to -20 so the system won't freeze. My problem is that Autobahn driving is disgusting in bad weather and the wash is constantly being used. Moreover, the wind-chill makes the wash very "goopy", so warming it a bit might make a big difference.
bpman - your system sounds better but I'm not that technical Sad
Worth thinking about though before buying...
Incidentally, if I do go for the Heat Shot, once the live is through the top of the bulkhead, what's the neatest route to the battery?
Post #113428 8th Jan 2012 10:55am
Mountain_man
Wales
Range rover sport heated nozzles are under £10 a piece....
Post #113433 8th Jan 2012 11:09am
Xcelsius
The Heatshot was added to GM cars in the USA not too long ago. There were recalls due to the units and fires. GM basically put the company making them out of business by suing for the cost of those recalls. I think fuses were externally added to get over the issue. Now it looks the same units are being sold in the UK through distributors from another company who bought the rights to the product. I personally wouldn't install them unless I knew for sure those fire issues from the USA were solved through some type of design change.
http://wheels.blogs.nytimes.com/2010/06/11...ns-deeper/
I haven't personally installed a set, but being as the history may not be known on this side of the pond, I figured I should at least put it out there for you guys to have all the info.
Post #113437 8th Jan 2012 11:25am
Gareth
I often wondered if the element out of a 12v travel kettle would work if sealed into the washer bottle. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #113445 8th Jan 2012 12:46pm
that's a good idea... also there was a mod to use peugeot spray blades on the wipers to spray the water.
i guess you need to think about all the points of failure for washer jets, what extremes you are going to use them in and design something. RR heated nozzles sounds like a good starting point, pop them into the bonnet and loose the stupid LR standard washers, a heating type element with a cut out (you need is warm not boiling) that is switchable.
time for a think ... maybe DG will see this too... if Olaf (entreq) sees it, expect something shiney and expensive Laughing
Post #113452 8th Jan 2012 1:08pm
Laurie
The antifreeze in washer fluid is usually methanol.
The heat generated under the bonnet (especially after the engine is turned off) will evaporate it from the washer fluid.
After a while it doesn't work any more. Sad
Post #113466 8th Jan 2012 1:25pm
Might also affect the paintwork ?
Post #113470 8th Jan 2012 1:34pm
Laurie
Use vodka instead..... Rolling Eyes
Post #113472 8th Jan 2012 1:37pm
Page 1 of 3 123>
