Home > Td5 > Wiper Motor |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
ive got a nasty feeling its a dash off job. I had to get my screen washer replaced last winter and they removed the dash to do that
Pom |
3rd Jan 2012 7:09pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
yep dashboard jobby its not to hard all you need is a screwdriver top dash section remove heater vents and 3 big screws 1 either end and one in middle then depending if late dash or early take the black plastic piece out not the center console were the radio is however that stays in ( the silver part in the picture stays) then remove the speaker and that section of the dash as that is only screwed on seperatly
Click image to enlarge pic of my old 90 200tdi wiper motor is roughly in the same place ( i was sticking td5 dash in ) |
3rd Jan 2012 7:19pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Depends on the age of the TD5. If its pre 2002 then its very easy, if its post 2002 the a little more difficult. No need to take the dash off though. Once a few bits are off and the screws are taken out there is enough give in the dash to get the motor out without removing the dash. Once you have done it once its easy!
Pete. |
3rd Jan 2012 9:43pm |
yer try it yourself first mate if you get stuck take it to a local garage worth trying save on the £££££'s
3rd Jan 2012 10:04pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Killer, your photo isnt showing for me, could you repost please?
4th Jan 2012 8:53pm |
Click image to enlarge there we are has that worked mate if not try the link http://i52.tinypic.com/2wnr12c.jpg |
4th Jan 2012 8:55pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8078 |
before you go the new motor route just check the spindles that come through the bulkhead havent seized.
remove motor and try and actuate the worm by hand, if it doesnt turn the spindles then change them, only about £7 each but that is a dash off job! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Jan 2012 9:10pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 616 |
This is exactly what happened to me on my 03 plate TD5 90 2 days before the MOT!! Had spindles replaced and all's well now. |
4th Jan 2012 9:21pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
mikeyp, depending on where you are in Ldn, if you get stuck, I can't recommend Foley's enough although there are prob plenty of independent's closer to you
http://www.foleyspecialistvehicles.co.uk/ |
4th Jan 2012 9:26pm |
hey seb i work for foleys i thought i recognised your landy were abouts in essex are you
4th Jan 2012 9:51pm |
Hello Killer! I'm near Ongar. My 110 was in recently for a new wiper park switch and dead driver's door window motor.
4th Jan 2012 10:00pm |
haha sweet good to hear the great feedback did you see the lovely monte carlo blue 90 with black stripe lowered springs and 20inch matt black rims in the car park this one to be exact
Click image to enlarge (if you hadnt guessed thats my one ) |
4th Jan 2012 10:10pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
What make is your steering guard Killer?
Visited Foleys about 10 years ago - good blokes |
5th Jan 2012 7:55am |
im not sure i know that terrafirma make one which is very similar mechanic fitted one today at work looks just as good TF841R <----- part number
5th Jan 2012 5:41pm |
