Home > Wheels & Tyres > What tyre size should I get?
Romadog
110 CSW V8 with Wolf 6.5j wheels.
What tyre size BF Goodrich All Terrain should I get ??
235 / 85 - 16
or
265 / 75 - 16
Post #110145 26th Dec 2011 7:43pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Your choice.
235 standard fit and best all round performance and slightly cheaper. 265 for looks and........
I'm sure others will advocate the supposed benefits Rolling with laughter
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #110152 26th Dec 2011 8:28pm
Romadog
Thanks Steve
My local stockist has around 50 265s in stock, but 235s are on back order.
Need to know what negatives there are for going to the slightly wider 265
Post #110155 26th Dec 2011 8:44pm
Dave-H
Romadog wrote:
Thanks Steve
None really ... it is all down to personal choice. worse you may need to do is adjust your steering stops slightly to prevent them catching the radius arms on full lock [simple to do, takes a few minutes]
I run 235's on my Defenders for over 12+ years, started using 265 about 8/9 years ago simply as i think they look better. I've not noticed any handling or performance difference whatsoever, on or off road. Guns and Landrovers .... anything else is irrelevant.
Post #110160 26th Dec 2011 9:12pm
RED-DOT
I once met a guy who ran Land Rovers entertainment and corporate days etc and he said 235's are the best all rounder by miles and anything else was for show... thats why i run 265's! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #110196 27th Dec 2011 10:20am
Romadog
265s x5 purchased today and fitted to black wolf wheels -
white writing to the inside Thumbs Up
Post #110217 27th Dec 2011 4:49pm
BigMike
spot on Thumbs Up
Post #110218 27th Dec 2011 4:50pm
ibexman
Thumbs Up Thumbs Up
Post #110228 27th Dec 2011 6:07pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i have 235 BF Goodrich All Terrain on my TD4 90, just bought a brandnew set of 5 for my new 110. LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #110262 27th Dec 2011 8:31pm
john adam
France 2010 Defender 110 Puma 2.4 SW Keswick Green
I am also planning to change tires and wheels of my land. I would prefer the standard 235/85R16 size for BF Goodrich All Terrain , but I have some doubts concerning the wheels. Basically the choice is between Modular and Wolf wheels. Wolf are my favorite, but: 1) they should be painted; 2) on Paddock web site it is marked that “it is sometime necessary to purchase extended wheel studs”. Is this true also for Puma? Modular are already painted and cheaper, but less robust (even if probably well adapted for standard use).
Any suggestion? Rolling Eyes
Ciao
Carlo 1971 88 Series IIA somewhere in Southern Italy
1989 Ninety stolen in Paris
2004 90 TD5 gone
2010 110 S Puma TDCI running
Post #110337 28th Dec 2011 12:15pm
Romadog
There are other threads on this, but YES you do need new studs with Wolf rims. DONT listen to anyone saying that they have had Wolfs on standard studs and had no problems......yet ! The Wolf rim is heavier than standard rim this partly due to steel being thicker especially in stud hole area, hence need for longer studs. I dont think I need to go into insurance and the fact that you've been advised to fit them by supplier. Yes they are covering themselves, but dont you want to cover yourself too ?!
Post #110380 28th Dec 2011 4:47pm
john adam
thanks.
carlo 1971 88 Series IIA somewhere in Southern Italy
2004 90 TD5 gone
Post #110435 28th Dec 2011 8:25pm
