Home > Technical > 240v inverters ...
Page 2 of 2 <12
mse
Under engine and fuel heaters...via a parafin burner used to be common (we have one) from the 60's/70's! Mike
Post #109737 24th Dec 2011 1:05pm
T1G UP
i have a 3000w inverter from maplins we had in our works van. Bit big but will run just about anything 240v i've put on it. microwave the lot.
also to big leisure batteries that run it.
Can sell if anyones interested?
http://www.maplin.co.uk/3000w-dc-12v-to-ac-230v-invertor-226535
Post #109739 24th Dec 2011 1:17pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Personally I would spend the (same or less) money on a range of 12V chargers and go without an inverter. Inverters are very power inefficient and the cheap ones put seriously nasty harmonics into your eletrical devices. Inverters may only be 50% efficient if you use a big inverter for small power needs - e.g for charging your camera battery. And then your equipment takes the 240V and converts is back down to 5 or 12V for (many of) the electrical circuits with more inefficiency
I bought a whole load of 12V chargers for camera, phones, laptop, GPS etc for less than £100 and I can use all of them at once and in other cars too. I can leave them charging overnight in silence. Inverters can also be a good source of RF noise too. Increasingly, small devices are using USB based charging which can be used across a whole load of devices - my lap top for example recharges my phone, video camera, etc
If you plan to take a fridge then the overland models often have 12V and 240V inputs if you plan to take it into the hotel room or to hook up
If you're thinking of heating then 12V and/or diesel based heaters are available
Also if you get 12V wet it won't give you a 'kick' like 240V will. If your inverter goes down (I think they are pretty reliable though) then you will lose all your electrical devices.
Fires under truck: my Coleman dual burner will do just fine, or get some diesel additive
Post #109861 24th Dec 2011 9:11pm
BigMike
John, the vehicle has a steel tank Thumbs Up
Post #109867 24th Dec 2011 9:44pm
BigRuss
Steve I think you need to get some heated washer jets Thumbs Up
They could also double up as a hair was system Whistle ready for the hair dryer plugged into the inverter Thumbs Up Russell
2011MY 110 XS USW Black
Post #109895 24th Dec 2011 11:51pm
I have been reading SteveS post - spot on - that's the approach i'm going to take.
Post #109947 25th Dec 2011 10:27am
Page 2 of 2 <12
