![]() | Home > Maintenance & Modifications > 3 Point Seat Belts in 90 ? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
3 Point seat belts are no good if your sat sideways
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Welcome Ridgeway to the forum.
I was in the same dilemma when I bought my 110 (I have 4 childrens). finally I decide for a Puma, one of my reasons to do not buy a 2006 model was because the child seat were not designed to be used in the inward position and under this conditions does not provide any safety for the childs in an impact. Sincerely, If you have childrens that use child seats in a 90 pre 2007, I would prefer to take away this inward seats and change them for seats facing to the front (with 3 point seat belt). With that you will loss space and at least one seat but in case of an accident will be better. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Ridgeway Member Since: 09 Mar 2009 Location: Lausanne Posts: 2 ![]() ![]() |
Sounds like a 110 will be better in that case.
Thanks |
If you're moving kids around then it has to be a 110 in my opinion. The 90 is a great truck but you can't safely fit child seats without replacing the rear drop-down seats. The only safe replacements are quite expensive (Exmoor trim do a set and Bearmach distribute globally).
I've had a 90 and have now opted for the 110 as we now have kids. A definite improvement. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Agree with that, a 110 will be far better and also give you a lot of space to load all the things that the childrens like. Cheers and have a good luck! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
