![]() | Home > Puma (Tdci) > SOLUTION? |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
That is very interesting, so my suspicion that it is the prop shaft seems to be correct.
I found exactly the same vibrations at pull away using the Td5 prop shaft which is why I put up with the grooing(and LR wont honour my waranty when the Td5 shaft is fitted), at idle my vehicle used to vibrate so badly that it became more of a shake at times, like the vehicle was about to take off or something, strange phenomenon. Why do LR not diagnose, or accept that this is a problem? |
try this: - remove the screws from the diff. - rotate the rear shafts (front and rear) 90° (clockwise) - test the car - if the vibration is increased try to rotate -180° and test again let me know..... Daniele |
felos Member Since: 24 Nov 2008 Location: Athens Posts: 12 ![]() ![]() ![]() |
Sorry but I dont understand,remove the screws attaching the rear propshaft to the diff and rotate the halfshafts?
Thanks George. NOT A TRANSIT |
you rotate the complete rear shaft (from the central diff to the cardan closer to the rear diff). put the tranfert box in neutral. |
