![]() | Home > Maintenance & Modifications > 90 side step fitting - where does this hang from/mount to? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1885 ![]() ![]() |
Hi folks,
Car I'm working on at the moment (1998 300Tdi 90) had these steps. They were removed and galved during the strip-down and now we're getting close to re-fitting them. I either don't have, or can't find the pics I took when they were removed. ![]() Click image to enlarge It ought to be bleeding obvious, and I think it is at the front. I think this is the O/S, driver's side, and that the end nearest the camera mounts onto the bulkhead/chassis bolt (I can't see any other way to get it to fit). But the question is where does the rearmost end go? I think it should be where the rear tub mounts to the outrigger, but the alignment isn't amazing. Perhaps it would look better if the front end was properly fitted, but just holding it in position I'm not 100% convinced. Alternatively, maybe I've got the wrong end of the step completely! Any advice or (even better) some pictures? Thanks! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
See these fitting instructions https://www.lrworkshop.com/parts/STC8438AA Different side step but the mounting is the same.
Excellent, thanks!
![]() It looks like we're now missing some of the fittings - the packing pieces for the hole in the rear outriggers, but I'm sure we'll be able to make something up. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
No problem at all. I only found that LRW had original instructions a few weeks ago when I got that bull bar. Very handy resource.
