Home > Puma (Tdci) > Weird noise TC light
M7even
United Arab Emirates 2014 Defender 90 Puma 2.2 LXV Hard Top Santorini Black
Hi guys,
Lately i have been noticing that when turn from a stop and while releasing the clutch there is a weird Burring sound and the TC lights comes on for a millisecond and then everything goes back to normal. its something that started happening since a couple of months and want to know if its anything to worry about.
EDIT: Forgot to mention that it happens every once a while, not very frequent.
Post #856227 15th Sep 2020 9:26pm
jst
defender with DSC? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856247 16th Sep 2020 5:43am
HardCharger
That's the traction control momentarily kicking in. It happens.
Could be one of the tires slipping before gripping or something?
Post #856254 16th Sep 2020 6:49am
jst
or with DSC picking up a false feed as it sounds like system about to operate TC but not actually getting that far.
steering sensor alignment, wheel sensor failure possible issues. depends on age if has DSC Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856258 16th Sep 2020 7:21am
M7even
Hello,
Reviving this old post, Took it to an LR specialist and he hooked up a OBD2 scanner just to look at the live data from the speed sensors of all four wheels, 3 of them showed the same speed from pulling away except one which was stuck on 1, he just tapped the speed sensor a bit and it got fixed!
Now when pulling away there isn't any noise and no flashes, I hope this helps anyone with the same problem. 2014 Defender LXV
2023 Defender 90 HSE
Post #999405 10th Jul 2023 7:03am
I had an issue once with a faulty sensor on my Disco2 which was giving a high reading. If you cleared the fault and drove off, the TC would immediately brake the FNS wheel hard, which was rather disturbing. It would eventually realise there was a fault and shut down the TC, ABS, and HDC (illuminating the three amigos). A new sensor fixed it.
It was the first (and so far only) time I've had a TC system try to kill me.
Post #999412 10th Jul 2023 8:18am
drivetrainshunt
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
This is identical to what mine is doing. Diagnostics showed a wheel sensor. I’ll be ordering one and swapping out to see if it fixes it.
Post #999751 12th Jul 2023 9:10am
M7even
mine got fixed with a slight tap to the sensor, good luck with your fix! 2014 Defender LXV
Post #999772 12th Jul 2023 11:12am
