Home > General & Technical (L663) > Check engine loss of power sometimes |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
hello, you have not specified which engine we are talking about, a diagnosis with instrumentation is essential for a problem of this type. There could be many causes...... When the yellow engine light comes on, your car goes into protection, therefore reduced power. Among the most common causes: dirty or faulty throttle valve, dirty egr valve, faulty sensor, etc….I don't see a relationship with HVAC. Surely in the dealership by interrogating the fault memory they can have an idea of the problem.
11th Jul 2023 6:07am |
Needledown Member Since: 12 Oct 2020 Location: New York Posts: 23 |
4 cylinder turbo
how do I clean dirty throttle valve? so when it looses power after an hour the check engine light comes on then after a couple of ignition on and offs. back to normal power but check engine light stays on for 24 hours then goes off all weird I only mentioned HVAC because it was in for service for a faulty malfunction of HVAC in heat mode. SO I guess ill try and hit dealer when engine light is on and in lower power mode and not turn off car see if someone can hook up asap but that's a long shot these dealers are so backed up with service. |
11th Jul 2023 7:52pm |
hello, the defect as an error should remain in memory, did the dealer tell you that they did a computerized diagnosis and there were no errors? it seems very strange to me.
In your place I would immediately go to the dealership and have the diagnosis connected, complaining about the serious problem. Cheers Marco |
12th Jul 2023 4:31am |
So after the dealer read the code it said Fuel Pump LOW CIRCUT
now I have an appoint meant Aug 22 for them to tear apart and see what's up SO sometimes I drive and it's fine. some sometimes the throttle is super slow to respond if I pull over and restart the car its fine again. Then it comes back then I pull over turn off and on and it's fine. Any ideas? I'll also keep you posted. the dealer said the seats have to come out to inspect so they needed 2 days so I waited for a date they have a loaner . 52k miles I did buy some extended warranty lets see how that goes aa |
26th Jul 2023 7:56pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2300 |
VCV? > 110 XS Double Cab
27th Jul 2023 7:02am |
