Home > Technical > Dead key fob
RaenerPuma2007110
United Kingdom 2007 Defender 110 Puma 2.4 CSW Barolo Black
Dead key fob
Spare key fob is completely dead. It’s the first time I’ve tried it since buying so not sure if it ever worked. Previous owner said something about it being a service fob???? But it looks like the other one which works fine.
(2007 puma csw)
I’ve tried changing the battery. Also the 4x lock button and 1x unlock button sequence someone suggested.
Inside it all looks pretty pristine.
Any thoughts?
Post #998243 2nd Jul 2023 9:15am
tommac
United Kingdom 2001 Defender 110 Td5 DCPU Alveston Red
Could well have a dry solder joint; anything obvious on the joints?
Post #998287 2nd Jul 2023 3:53pm
RaenerPuma2007110
They look ok as best as I can tell
Post #998431 3rd Jul 2023 5:00pm
peanutbob
Try swapping the batteries from the main key fob to the spare and vice versa in case either the new battery is a dud or is a cheap version that doesn’t have enough amperage to work the fob.
Duracell batteries are fine …the ones sold by Timpsons are not .
Post #998446 3rd Jul 2023 6:10pm
Ianh
It may not have been coded to the 10AS alarm module, you will need a Nanocom to check and if needed code.
Post #998451 3rd Jul 2023 6:38pm
spudfan
Ireland
When I got my 2011 Defender it only came with one key and fob. I contacted Land Rover who had one sent to a maindealer as it had to be matched to the vehicle. Don't know how they did it but they needed the vehicle for a short time while they were doing it. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #999197 8th Jul 2023 1:07pm
Ianh
That’s what I was pointing out spudfan, each remote needs to be coded to the 10AS or ALM alarm module. The OP will have a 10AS from factory. To do this you need dealer diagnostic equipment or a Nanocom. It’s a very simple procedure.
So if the spare remote had not been coded or for some reason it’s coding had been corrupted then you can check / rectify with a Nanocom to save the cost of the dealer doing it. Hopefully a forum member close by with a Nanocom can help the OP out.
Of course it could be a faulty remote, in which case the recoding won’t work and points to a remote issue.
Post #999457 10th Jul 2023 12:17pm
RaenerPuma2007110
Thank you for all the comments.
If anyone has a nanocom coder near Bournemouth, pls drop me a message.
Post #999480 10th Jul 2023 1:23pm
Ianh
If it transpires you have a remote issue have a look at remotekey site for options. https://www.remotekey.co.uk/category/land-rover/defender/
Post #999485 10th Jul 2023 1:34pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
+1 for remote key.
You could just get one of those and do away with the separate alarm fob and have it built into the key.
I got one 6 months ago and it's great. It will program/code itself when you first set it up so there's no dependency on your current fob. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #999520 10th Jul 2023 4:59pm
Ianh
If you can’t find someone local to help you out for free with a Nanocom then it will likely be cheaper to get a new fob or fob plus key provided and coded by remotekey than getting LR to run diagnostics and code your old fob, and that’s if it is not a fault with the fob.
Post #999619 11th Jul 2023 11:38am
