Home > Wheels & Tyres > Goodyear Wrangler Duratrac
nidge n
Hello all, I have a set of Goodyear Wrangler Duratrac 265 - 75- 16 fitted to my landy, one of which has suffered a puncture. I can't seem to find a replacement for this size with one supplier suggesting that they are out of stock until August. A couple of questions, if anyone can help on the supply side that would be great and 2) do i need to replace both tyres that share the same axle (rear). Existing tyres are about 10,000 miles old. thanks all
Post #998055 30th Jun 2023 3:30pm
markb110
I know that these guys are out of your way.
But Tadworth Tyres near to Epsom Racecourse are one of the only companies I know of that can patch a tyre and re vulcanise it. Not just a pushed through from the inside patch as the mainstream do.
They can also repair a tyre to 1 inch from the rim using the same method.
www.tadworth-tyres.co.uk
The website doesn’t make it clear that they still offer this service so worth a call, if they do then it is an overnight service as the tyre is baked in an oven.
Hopefully they’ve not been taken over by a profit before service since I’ve used them.
Good luck.
Post #998071 30th Jun 2023 6:03pm
nidge n
Thanks Mark,
Saving the existing tyre may end up being an option if i can't find the supply of a new replacement.
Post #998127 1st Jul 2023 7:52am
markb110
I had a look locally but they all seem to be 19inch plus.
Post #998132 1st Jul 2023 8:51am
