![]() | Home > Technical > Body alignment after chassis change, 130d/c |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
Fit the Hicap tub first, then align the rear bulkhead to this. This should get the rear bulkhead height roughly correct, and work forwards - although 130’s / hicaps often came out of the factory with misaligned bulkhead / rear tubs - the tub often sat slightly higher at the back so you could not achieve a parallel line through the cab to the tub.
POD Member Since: 05 Sep 2022 Location: Australia Posts: 3 ![]() ![]() |
Thanks for the reply, seems there's not a lot of experience in 130 chassis swaps out there. My vehicle was delivered as a cab / chassis and has no tub so that reference point does not exist. I spent a third day on the alignment yesterday and managed to solve the problem and achieve acceptable (by defender standards) shut lines; I had to remove the brackets that support the back of the seat box, i.e. the middle part of the cab, as they were forcing the middle of the cab to sit too high. This allowed the rear to sit down more, got a reasonable alignment at the bulkhead-front door-windscreen frame area. Presumably the horizontal alignment between the three outriggers is significantly different to the original chassis. First on today's job list is to fabricate adjustable brackets to replace those that had to be done away with.
I had expected a much easier time in aligning the body on the new chassis. Several decades ago I swapped body shells on a land cruiser and don't recall any problems getting things lined up. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2695 ![]() ![]() |
Fairly common, particularly with aftermarket chassis. Persistence and sometimes some modification will get there in the end.
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 639 ![]() ![]() ![]() |
During last two winters I have completelly striped 130 HCPU TD5, and before it, there was 2 cm side possition offset of the body to frame. After this, I take it, that Defender and accuracy cannot meet. During completatinon I let all a bit loose and started fight to have all screws fitted together. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
A bit of an update, I fabricated some adjustable brackets for the centre body support which greatly improved the situation, the door gaps on the driver side are spot on, passenger side are not as good as they were before but at a point where I can live with them. I pulled the head lining out and loosened all the bolts around the roof to aid in getting everything lined up; didn't seem to help a bit! I installed body deadener to the roof whilst it was exposed so hopefully that was worth it. Also got rid of a couple of shovelfuls of outback dust from up there.
I've been putting in almost full-time hours on this vehicle for the past 5 weeks, currently building a new tray complete with an under-tray drawer which will house 2 spare wheels. Many frustrations, such as the front tray brackets on the chassis being welded on at different angles! I did all the measurements on the right hand side, designed and fabricated the two brackets as a mirror pair and then found the left hand side bracket was 4mm lower and 5 degrees further off the horizontal! Hope there aren't too many more variations like that or the thing will be driving sideways- although perhaps a defender is more aerodynamic that way. |
