![]() | Home > Expedition & Overland > Safety/security tips |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Hello,
Dummy wallet what a great idea. No jewelry or fancy watches, keep nice cameras out of sight. I feel most comfortable carrying as little as possible in areas I do not know well. ie no bag. Try to look like I dont have much money, which is quite easy ![]() Steve |
Just come across this whilst having a browse, so thought I'd add this little nugget...
If your vehicle is fitted with central locking then it's worth disabling it on the rear door. It's very easy for 'locals' to open rear doors and grab whatever comes to hand. Nearly happened to me once with a Disco I in Morocco. I was just pulling off and some kids made a bid for the rear door. I stamped on the brakes and the weight slammed it closed again, but we travalled with the doors locked from then on. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
on the same thread as the dummy wallet, i did read of some overlanders getting a built in secure lock box, then got a cash tin and a bike lock and stashed some randome notes old credit cards and expired pass ports,
i've also been told that (but not managed it myself yet) that there are two catches on the puma gear stick, you press in both sides through the rubber boot and the gear leaver comes loose and so stops gears being changed, when i manage it i'll post some pics. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5060 ![]() ![]() ![]() |
A high res colour copy of you key documents (a few of them) help - that way you can hand them over and not worry if you dont get them back Mike
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
This sounds interesting ![]() |
taking the gear stick off isn't worth doing as the remaining section is long enough to change gear with no problem, plus if you want to try it, please don't pull the stick through the rubber gatter, its a b**ch to pull back over! |
Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
agreed. Jack |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Best tip for documents is to get a hi res scan of them, then e-mail to yourself. that way, you can access them (as long as theres web access) anywhere in the world
A friend of mine also declared his passport stolen, then got a new one from passport office. That way he has what looked like a genuine passport ( ie no corner cut off and expired one). If held up, he could give the old "stolen" passport to the thief. Its of no use as it would be confiscated as soon as anybody tried to use it. Most criminals in these places are fully aware of safes and lock boxes overlanders fit, so it may be worth the old double bluff. Hide your valuables somewhere and place a few quid and old credit cards in the safe. |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
Massive error. Falsely reporting a passport as stolen is fraud and potentially carries a custodial sentence. If you think HM Customs won't ever find it, get down the docks and watch them do a vehicle search some time. |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
A good point! Don't make the mistake of assuming all thieves are idiots, for some this is their living and they are good at it. They are more than aware of the things you can do to "fool" them. |
