Home > Td5 > Head job and Hylomar
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Hi,
I've started reassembling the refurbished engine. I checked the manual and the other sources and could not see if we should - or if it is recommended - to use hylomar (or some copper spray) before fitting the head gasket. Logic would dictate no need but I was hoping to take on some knowledge from the experienced TD5 drivers
The use of it between the camshaft carriage and cylinder head I'm aware of, but otherwise I'm not certain.
Thanks Td5 110 Station
Post #996864 19th Jun 2023 3:55pm
landy andy
No. No sealer required. Thumbs Up
Post #996866 19th Jun 2023 4:35pm
NickMc
Re: Head job and Hylomar
Thanks
This needs an anaerobic sealer fitted as it’s between two machined surfaces which is basically a cam bearing so nothing with any thickness. It cures in the absence of air.
Something like:
https://www.permatex.com/products/gasketin...ker-50-ml/
Post #996867 19th Jun 2023 4:43pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I have always used Wellseal for this type of joint, I used it on my TD5 when fitting a new AMC head.
The main reason is you don't want any squeeze out of the sealant that could find its way into the oil galleries.for longevity it never seems to completely dry out. Just paint it on the face for sealing leave a few minutes and assemble.
Have used it with no problems for over 30 years, I was told it was originally developed for aircraft engines during WW2. Still use it on aviation engines to this day 👍
Edit: On the cam carrier joint not the head gasket joint.
Post #996907 19th Jun 2023 10:45pm
