Home > Td5 > cooling pressure issue
olistr
Germany
Hi,
I have a TD5 from 2002, all stock, it has 320k and when I am driving a while, pressure is building up in the cooling system.
When I stop the car, the cooling level is far down, when I open it, it bubbles a little and air comes out and then the level goes back to normal.
I have been in the garage, they are saying there are no signs of exhausts, in the cooling, so it is somewhere else.
It is not heating up, no loss of coolant.
Any Idea where this could come from? The garage couldn't find anything and suspects the motor block potentially being cracked.
Any suggestions are welcome.
Olivier
Post #996216 14th Jun 2023 9:14am
rallysteve
The issue is likely the head gasket failure and movement of the cylinder head due to Land Rover's use of plastic dowels between the cylinder head and block.
In theory the 10P version of the TD5 engine (pre MY02) used plastic dowels and the 15P version of the TD5 engine (MY02>) used the improved metal dowels. I had to replace my cylinder head a few years ago on my MY02 15P and mine was fitted with plastic dowels which were both almost sheared off.
Post #996226 14th Jun 2023 10:09am
olistr
Germany
wouldn't head gasket issue mean signs of exhaust in the cooling system? which is not the case
Post #996227 14th Jun 2023 10:15am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Coolant level on the expansion tank is for COLD engine. When hot, it is a bit different. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #996229 14th Jun 2023 10:48am
olistr
Germany
Hi Madtom,
I agree, the lower level is just a consequence of the high pressue,
what I am worried is where the High pressure is coming from and the bubbles as the coolant was tested and no signs of exhausts were found
Post #996230 14th Jun 2023 10:50am
A.Rubio
Spain
Hello, before opening the engine check that the expansion tank cap works, this cap must open its valve at 1.4 bars and sometimes due to dirt in the circuit its valve can clog. The pressure in the cooling circuit of the Td5 engine is usually between 0.5 and 0.7 bars when hot with coolant at 90ºC if your circuit does not lose water.
The places that pressure can reach could be: for one of the cylinders, the most propitious is usually cylinder No. 1, the one closest to the fan, this is the one that has caused the most problems.
Due to the diesel refrigerant exchanger since the diesel is at a pressure of 4 bars but this can be detected with detectors, it is normal for this cooler to lose water through the joints but not for them to mix.
That the pump injectors put pressure on the water circuit inside the cylinder head but this problem is very rare since in the P10 the return circuit goes through the cylinder head.
Due to the refrigerant oil cooler, it is easily detected because the oil cap has a coffee-au-lait color and the oil pressure is higher than that of the water circuit.
Removing the heaters and putting pressure to the water circuit up to 1.5 bars and with an endoscope type video camera
https://www.amazon.es/Lightswim-inspecci%C...7KP5D?th=1
the only problem is that number 1 does not have a heater
Well I can't think of anything else right now.
Post #996259 14th Jun 2023 4:16pm
A.Rubio
Spain
Oh I forgot, I hope there is no air in the water circuit, bleed it in case there is an air pocket inside and open the heating circuit.
Greetings
Post #996260 14th Jun 2023 4:22pm
jimmyvonk
United Kingdom 2004 Defender 110 Td5 CSW Epsom Green
Get a new header tank Cap - see if that helps..
Post #996538 16th Jun 2023 9:55pm
MadTom
Or try to drive with the expansion cap loose, letting the coolant system work without any higher pressure. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #996559 17th Jun 2023 6:46am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I'm no expert, but I've just replaced the head gasket on my straight 6 diesel.
The symptoms were no water or steam coming from the exhaust, no milky oil but coolant was being pressurised. Driven steadily it was fine, but on a hill when more power was needed the water system would gain pressure and water would burst out of the expansion tank, leaving the engine temperature in the red and the expansion tank empty.
A new head gasket fixed it.
Post #996570 17th Jun 2023 8:18am
olistr
Germany
so I repleaced the cap with a new one, the issue decreased but the bubbeling is still there, even just after a 3 min. run in idle. I think the new cap is just hiding the symptoms.
Post #1000834 19th Jul 2023 4:31pm
