![]() | Home > Technical > Anti roll bar kit does not fit (salisbury rear axle) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 ![]() ![]() ![]() |
I swapped my axle from a Salisbury to a later Td5/Puma type, and the rear bar fitted straight on
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Yep, all factory ARBs are the same 02' 110 TD5 Double Cab Rebuild Thread
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
I know nothing about ARB’s apart from how to remove them. But could it be a front one? Are they different widths? Sizes?
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Check the parts number. From memory, your ARB should be a straight version.
Secondly, I run about 60-70mm lift with 10"shocks myself and have not found a way to space the ARB right yet. My current spacer seems to make the ARB chewing through bushes at a speedy rate (have to say my 110 is offroad only, but bushes hardly lasting several trips). So best keep an eye out and may adjust your spacer. M |
Eppilihp Member Since: 10 Aug 2019 Location: Emmental Posts: 61 ![]() ![]() |
It's weird. I suspect the mounts on the axle sit a tiny bit further apart and/or are a bit wider since the ARB itself is definitely too small.
I measured my ARB, it's 99.3cm (on the inside), could somebody confirm that this is the "regular" size? ![]() Click image to enlarge And no, it's not a front ARB, those are even smaller and have a different shape. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1662 ![]() ![]() ![]() |
Aftermarket chassis or just crossmember? I’m sorry I don’t have any Salisbury axles or vehicles, I do have some anti roll bars in storage, but someone might have one handier than me.
All original
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
Does look curiuos, mine is non standard but fits exactly as you have.
Just a thought but when i was fitting mine i used the extreme 4x4 kit as a reference, which confused me more as they show the droplinks on the outside as opposed to the inside? Not sure why but this may help? https://extreme4x4.co.uk/products/anti-roll-bars-bushes |
So how did you install your ARB? With the droplinks on the outside?
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 491 ![]() ![]() |
Better to delete ARB with lifted suspension as its a conflict of purpose, the inclination of the bar just leads to excessive bush and link wear.
I didnt couldnt make it work, kept looking at the pic but did mine as the OP has but mine seems fine |
