Home > Technical > Footwell stud on TD5 bulkhead
rallysteve
I noticed a funny little button on the underside of the driver's side footwell on my Td5 bulkhead whilst repairing it. I wondered what it was at the time but have just noticed it again whilst cleaning up post galvanising. After a bit of looking at pictures online, it seems it should actually be a stud, mine has just been cut/snapped off.
Does anyone know what it is used for? Highlighted in the below photo from ebay:
Cheers,
Post #995654 8th Jun 2023 7:04pm
NickMc
Earth strap cable to front bulkhead rigger goes there. There’s a stud and then a rivet type nut on the bulkhead rigger face.
Like so:
https://www.ebay.co.uk/itm/391975570553?mk...media=COPY
Post #995674 8th Jun 2023 9:47pm
rallysteve
Cheers, must have not had anything fitted on mine when i dismantled it then as there was no earth link there. Makes sense though. Will fit a new riv-nut to the bulkead and something on the chassis for an earth link.
Cheers,
Post #995719 9th Jun 2023 9:56am
NickMc
On aftermarket chassis the strap is long enough to reach to the bulkhead footwell mounts if they’re the through bolt style. Otherwise it goes where that square plate is welded on you drivers bulkhead rigger.
Post #995733 9th Jun 2023 11:51am
