Home > Puma (Tdci) > Water outlet elbow seal 2.4 puma |
Wethering Landy Member Since: 17 Jun 2022 Location: Suffolk Posts: 39 |
Thanks for your thoughts everyone. I have a couple of questions:
1. Does the oil pick up have a mesh to stop stuff other than oil entering the oil pump? 2. If a fragment got into the oil filter should it not be captured and therefore safe? 3. Once in the sump - the only place it could end up is the oil pump - if No1 is a no? If No 1 is a no - and the fragment could be picked up - and seize the oil pump - and snap a chain, then I can completely understand why sump removal is a must However if the oil pick up has a mesh then what other possibilities does a fragment have of getting back in once gravity has taken its effect? |
28th Apr 2023 8:09am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 |
Yes, there is a "sieve" in the suction pipe. But the particle shape and size is decisive for whether it can be sucked in. Take a needle, for example. It can be sucked in vertically, but not in a horizontally oriented state.
But if it is not removed, this is a latent source of danger, because it is moving. That's why I recommend magnets inside the sump. You want to ensure a clean system. |
28th Apr 2023 10:11am |
Thanks hornet. Sump off it is then. I think I will drain the oil and see what is on the sump plug and then piece together everything I have to establish what is missing.
I have located all 15 pin bearings luckily as these did not drop into the sump and stayed in the top of engine. I think there is one or 2 tiny pieces still un-accounted for though. Thanks for your advise. |
28th Apr 2023 10:43am |
Great
And could you please measure the "elbow", groove width and depth? I will select the O-Ringsize + material for coolingwater. |
28th Apr 2023 1:09pm |
Elbow size is:
4.35mm wide 2.88mm deep measured with digital callipers |
30th Apr 2023 7:59pm |
Thanks, inner diameter is of course important forgot to mention.....
1st May 2023 2:45pm |
Dear All
Just a note to say Thank You for all your advice. I have re-built the engine and it is up and running again and sounds like new. I re-used the water elbow seal in the end - but replaced the seal on the timing chain cover. All is good so far. So from me and my Lady - Thank You! Click image to enlarge |
5th Jun 2023 5:24pm |
