Home > Expedition & Overland > Which engine is best for overlanding?
Page 1 of 3 123>
Dunc99
Hi everyone,
I'm looking to get a 110 to convert into a camper and tour around Europe and I'd like your advice on which engine to go for.
Does the euro rating matter that much? i.e should I go for the 2.2TDCi (euro5) or will it not really matter in a years time and a TD5 (Euro 3?) would be fine if I'm not bothered about going into big cities?
I've read a few bad comments about the reliability of high mileage TDCis in transit vans, are the defender versions as bad (and I should stick to a TD5) ?
What is everyone's thoughts and experiences?
Many thanks.
Post #995052 4th Jun 2023 3:50pm
BrickBox
Everyone will have their own opinion. It’s all down to personal preference and budget IMO. I personally think the Puma 2.4 is the best. But some/most will not agree. 2008 2.4 110 Utility Station Wagon XS.
Post #995054 4th Jun 2023 4:05pm
landy andy
Id be going for 300tdi, or Td5 for proper overlanding, but Td5 is going to be much nicer and better for the faster stuf, and where power is required. I wouldn’t touch a Tdci engine. Nasty things.
Post #995069 4th Jun 2023 6:21pm
I'd second Brickbox and go for the 2.4 Puma, probably the engine best matched to the Defender. For absolute reliability coupled with maintainability for overlanding, the 2286cc petrol engine in a leaf-sprung chassis is probably unbeatable but is unlikely to be acceptable to anyone under 50 who's grown up soft on comfortable easy vehicles!
Post #995072 4th Jun 2023 6:57pm
Kiter25
Td5 all day long for me. 23my p400e x dynamic hse, fuji white, towing pack, comfort and convenience, e diff, activity key, 3 zone climate, cold climate and a host of accessories. Now gone.
Post #995075 4th Jun 2023 7:33pm
ickle
For a tour around Europe, the TDCI would be better, coupled with the 6 speed gearbox a nicer drive.
But mainly as the engine and its ancillaries are common to so many euro vans (not just transit) spares will be much more readily available.
The main thing is to buy the best maintained 300tdi/td5/tdci you can find - there are a lot of nails out there.
Good Luck
Keith
Post #995077 4th Jun 2023 7:55pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
OM606 or OM605 all mechanical, no electrickery involved. Should be easier to fix in the ar*e end of nowhere.
If you're not straying too far from civilisation, 2.4 Puma is the best choice.
Post #995129 5th Jun 2023 11:43am
Bluest
The only problem with the 2.4 (and I own one) it's it's apparent propensity for mysterious going into limp mode. That could be highly annoying in remote places. 2007 110 TDCi Station Wagon XS
Post #995197 5th Jun 2023 4:24pm
Hmm, I'd say that needs fixing!
Post #995206 5th Jun 2023 5:04pm
Moo
Ukraine
V8. Most are ULEZ compliant which means you can drive into cities where there is a restriction on older diesels if you deviate from your overloading. Sounds good as well and much smoother. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #995208 5th Jun 2023 5:07pm
camelman
Depends if you're proper overlanding in the back end of nowhere where you'll have to fix issues yourself or knocking out miles on the autobhan.
Post #995211 5th Jun 2023 5:09pm
landy andy
Exactly. Overlanding isn’t going into cities that are so modern that they have emissions criteria.
Post #995248 5th Jun 2023 7:14pm
jst
For comfort i would have a puma based vehicle. Better gearing abd better hevac.
Engine wise, somthing not stressed for the speeds you will spend msjority of your time at.
For me a 2.4 or 184 m57. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #995263 5th Jun 2023 8:27pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hmmmmm…
I would go 300Tdi for fixability in the middle of nowhere…
Jim
Post #995266 5th Jun 2023 8:59pm
I'm not sure that the 2.4 Puma is any less fixable than a 300 TDi, it just needs a different set of spares and some different tools. A common rail diesel is in many ways much simpler than a diesel with a traditional injection pump.
Post #995268 5th Jun 2023 9:28pm
Page 1 of 3 123>
