![]() | Home > General & Technical (L663) > Adjusting screen brightness |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1429 ![]() ![]() ![]() |
This is from the manual
Use the interior illumination control to adjust the intensity of the instrument illumination. The exterior lights must be switched on while changes are being made The control is number 8 on the diagram ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
Lower right hand side of the steering wheel on an RHD car.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Down in the cubby where the parking brake manual activation switch is - it’s a tiny press press and rotate button just below the parking brake Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
JustCallMeMac Member Since: 02 Jan 2023 Location: Southampton Posts: 25 ![]() ![]() |
Thanks everyone. Found it!
dshark1 Member Since: 17 Jun 2023 Location: Florida Posts: 20 ![]() ![]() |
Even at max , I find it a little dim.
mbso Member Since: 01 Sep 2021 Location: Genoa Posts: 101 ![]() ![]() |
You are right !! Me too !! DISCOVERY 4 2013
VOLVO XC90 2017 MY23.5 110 D250 SE in Santorini Black |
